E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > ISTA fault questions IBS missing and overheating
Reply
      08-13-2020, 11:56 AM   #1
vitez180
Drives: BMW 328i Cabrio
Exclamation ISTA fault questions IBS missing and overheating
Hi, just got a new to me e93 (my first BMW). Drove it the first time yesterday and it overheated and kept overheating and i hooked up ista today to check it out. I am getting water pump speed deviation and
power reduced.
Also the IBS says missing should I check if that's there? It seems like a pain to get to in convertible.
Also on a side note my right adaptive light warning is going off after i replaced the headlamp assembly but carried over the old ballast and control unit. Do i need to reprogram for it to work? Also the control unit got wet from the previous headlamp so maybe its bad if that's what controls the adaptive lights?
      08-13-2020, 11:57 AM   #2
vitez180
Fuses
Maybe I could check the fuses for water pump, all models have the fuse under the hood passenger side compartment?
Also the DSC lights came on also while driving with the orange brake light, so those dsc codes are current if anyone could chime in with what that can be.
Yay BMW experience
      08-13-2020, 01:04 PM   #3
ctuna
Drives: 325xi 06 wagon MT
Hope you didn't get this problem dumped on you.
broken belt
http://www.bimmerfest.com/forums/sho....php?t=1231881
http://www.e90post.com/forums/showpo...3&postcount=23
https://www.oxwerkzperformance.com/
http://www.e90post.com/forums/showthread.php?t=1477111
https://www.e90post.com/forums/showthread.php?t=1305990
If you had a low battery a lot of those could be false indications .
Clear Codes and see if they come back.
Making sure you have a good battery putting out over 12.4 volts resting.
codes that are in memory are not necessarily a consistent fault and a bad
battery causes all kinds of phantom codes.
Water Pump deviation probably needs you need a new one.
      08-13-2020, 02:37 PM   #4
gbalthrop
Drives: 2007 328xi E91
Originally Posted by vitez180 View Post
Hi, just got a new to me e93 (my first BMW). Drove it the first time yesterday and it overheated and kept overheating and i hooked up ista today to check it out. I am getting water pump speed deviation... Also the IBS says missing should I check if that's there? It seems like a pain to get to in convertible...
I also note you have a question about fuses in your 2008 328i E93 N51. Here is the TIS wiring diagram for the Cooling System. There are TWO fuses related to the Coolant Pump, and BOTH are on the JB (Junction Box) Fuse Panel beneath/ forward of the Glovebox. F33 is the Main Pump Motor Power Supply. F37 is the Control Circuit Power supply for both the Coolant Pump and the Thermostat (see right side of schematic).
https://www.newtis.info/tisv2/a/en/e...mostat/vFKjkjB
NOTHING related to the Coolant Pump is in the E-box under the Hood (EXCEPT the DME which controls it all ;-) "Missing" related to a component, doesn't mean the component has been physically removed, has fallen off, etc. It means there is NO SIGNAL from that component. In this case, my interpretation of that code is that the DME (which processes Battery Voltage & Temp measurements made by the IBS) is NOT receiving proper signals from the IBS, or at least WAS NOT receiving proper signal when the Odometer read "140752".
Also, you should be aware that either INPA or ISTA can "Connect" directly to the DME Module and get MUCH MORE detailed information on any fault code still saved in that Module. So make sure you let us know how/if you can use ISTA or INPA with specific information of how to connect, which buttons to push, which screens to view/ save/ attach, etc.
I will respond to the specifics raised by the codes you posted in later Reply, but please answer following questions:
1) I presume you first drove the vehicle yesterday?
2) How many minutes approximately elapsed between Startup & any Temp Warning Light?
3) Which Warning Lights appeared & what color(s)?
4) WHAT is the current Odometer Reading, and ~ how many miles ago did it overheat? Comparison with ISTA readout of mileage at which various faults occurred.
5) Was there any warranty related to your purchase/acquisition?
6) Do you have any reliable Prior Maintenance History or Documents?
7) If this is your first BMW & you first drove it yesterday, HOW do you have ISTA already?
8) Are YOU or whoever owns the computer generating the ISTA screen attached familiar with INPA which is on that computer as well? Reason I ask, is that I can explain some things with INPA screens, and suggest INPA tests, but I do NOT use ISTA.
George
      08-13-2020, 08:41 PM   #5
vitez180
broken belt
Could you specify why I should check for the belt, overall the engine gaskets look dry, i figured they have been replaced. But I forgot to add the fact that I got the car with a front right collision hit, I replaced the knee assembly, but I guess that's where the pump could have been damaged?
The battery seems to be resting around 12.4, possibly settles below I'd have to check again, but I'm pretty sure it has dipped a lot less before I charged it up since it hasn't been driven in a while before me.
      08-13-2020, 09:00 PM   #6
vitez180
George
Thanks for the reply George, I was worried about getting BMW, but the support community is pretty big and awesome. I should have mentioned that I got the car about a month ago with a front right collision, and I replaced the knee assembly mainly and headlight (but carried over the ballast and control unit). So throughout the time until i fixed it, I've been on the forums and found BMW Tools and also added ISTA, so I do have INPA also. Bought a K+D Kan cable.
2). So I drove it to get inspected about 30 miles one way and got the first orange coolant temp light about 20 miles in so about 25 minutes including startup maybe a few minutes more. It kept going on and off for a bit so thought it was malfunctioning, but later I figured the cooling fans came on full blast and must've regulated the temp a bit. But towards mile 25-30 it kept on longer than got a red light and I still drove a bit, I think it went to orange for a bit until I cruised to a traffic light in limp mode (red temp light) and turned it off for a bit, and finished the trip with orange temp light. Somewhere in between all that the DSC fail light came on (the triangle with the circle) and the orange brake light. CC-ID 24 and 35 i think specifically. The car hasn't had alignment done yet either so not sure how bad it is.
4). the current odemeter reading is 87464 miles, but I was told Ista shows km. But I can say for sure out of the faults shown in this picture the ones from 140600 is where my faults started showing up.
So no warranty or documents with the car and I opened up ISTA for the first time so that's all I know.
      08-14-2020, 07:01 AM   #7
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
You can do a water pump speed test in INPA but you have all the tell tale signs the water pump is dying, don't keep driving it. Also change the thermostat.
It is located on the passsenger side but they eventually fail. INPA is good for analyzing the IBS
      08-14-2020, 11:07 AM   #8
ctuna
The belt does not usually fail unless it gets oil on it.
As the tensioner wears out the belt will start to creep
of the pulley . I haven't seen anybody come up with a
good test for the spring tension test for the pulley.
The observational test is belt creep on the tensioner pulley.
Diagnostic Manuals Inpa/Ista D
https://bimmerprofs.com/diagnostics-inpa-part-1/
https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF
https://carmod.ru/files/icom/istad_en.pdf
https://www.e90post.com/forums/showthread.php?t=1681573
https://www.bimmerforums.com/forum/s...-P-actually-do
primary links
https://www.bimmerfest.com/forums/at...9&d=1539905743
https://www.bimmerfest.com/forums/at...1&d=1590283589
I would never drive these and inch farther when a red temp light comes on .
      08-14-2020, 10:55 PM   #9
vitez180
primary links
Thanks, I got these bookmarked now.
      08-23-2020, 10:26 PM   #10
vitez180
It was the water pump
The water pump connector was damaged from the collision, slightly pulled out. Replacement fixed it.
Reply
Tags
adaptive headlight malfunction, e93, fault codes, ibs, ista, overheating, programing, water pump
e90post
