BMW M3 and M4 - The Icons
home
G80 BMW M3 and M4 General Topics BMW M3 (G80), M4 (G82), CSL and 3.0 CSL General Forum
      08-23-2020, 05:31 PM   #1
kyrix1st
kyrix1st's Avatar
2374
Drives: G87 M2; E92M3 MT&DCT; M3 euro
2004 BMW Z4  [0.00]
Carbon fiber driveshaft?
Will this return to the base or Competition model for this generation?
I recall F8x generation base weighed around 1490kg with the lightest factory spec(MT, manual seats), coupled with CFRP body parts that actually have lightweight advantages.
As much as I appreciate their clarification I would also appreciate that mods stop editing my post content.
Pass me if you can.
      08-23-2020, 06:08 PM   #2
The Automotive Enthusiast
Retired BMW Genius
The Automotive Enthusiast's Avatar
Drives: 2018 Audi S5 Coupe
It's been gone for awhile. The carbon driveshaft was replaced with a steel driveshaft back in 2017. I don't anticipate it being offered for the G generation M3/M4. I think it may be linked to the fact that BMW had a recall on the carbon driveshaft eight months prior.
See link: https://static.nhtsa.gov/odi/rcl/201...8V713-2564.pdf
Originally Posted by LucBroDude View Post
TRAITOR.
TRAITOR.
      08-23-2020, 06:17 PM   #3
brad850csi
Drives: 16 F13 M6 Comp
It was dropped because of the need to fit the GPF and the chassis couldn't fit one any other way. So if they wanted to this time around I'm sure they could but as there has been no mention at all so far I'm guessing there won't be.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      08-23-2020, 08:38 PM   #4
xlover
Drives: 2023 X7 40i
Is there any data comparing the carbon fiber driveshaft F8x and the steel driveshaft f8x models to see if it actually made a difference? Or if it was more of a "because racecar" feature?
      08-23-2020, 08:46 PM   #5
Retired BMW Genius
A carbon driveshaft actually has a couple different benefits other than being able to handle more torque when compared to a steel driveshaft. One major benefit to a carbon driveshaft is that it absorbs vibrations better than a steel or even an aluminum driveshaft. For a car like the M3/M4, it was 100% a 'because race car' feature. BMW could have gotten away with a steel or even an aluminum driveshaft from the very beginning and nobody would have noticed any kind of difference. Weight savings from a carbon driveshaft and an aluminum driveshaft isn't massive.
TRAITOR.
TRAITOR.
      08-23-2020, 09:34 PM   #6
xlover
Drives: 2023 X7 40i
Yes that was my hypothesis as well, that the M3/M4 platform isn't really extreme enough to reap the benefits
      08-23-2020, 09:45 PM   #7
solstice
Drives: 2015 M3 6MT
My car has it according to specifications. Have I ever noticed a difference from a steel shaft? Nope. Do I care if it never returns in a car? Nope. Cool video though they made to launch it.
      08-23-2020, 10:01 PM   #8
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3459
Drives: 2020 M340i
2020 BMW M340i  [0.00]
I dont see it making a come back.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      08-24-2020, 12:44 AM   #9
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Weight wise, steel driveshaft actually outperform the carbon driveshaft. Because although heavier for the given strength, steel is smaller (exactly what made fitting GPF possible) and thus rotating mass is much less. Meaning, steel shaft is lighter and easier to handle at speed.
M3/M4 doesn't have enough power to bother with a carbon driveshaft, knowing, yes, 1000hp will be the new norm in the G8X aftermarket. Many things can fail along the way, before you will have to worry about the shaft.
Lemania 2320
      08-24-2020, 01:28 AM   #10
kyrix1st
kyrix1st's Avatar
2374
2004 BMW Z4  [0.00]
Have you measured the diameter difference between the two? It was advertised to reduce either rotating mass or weight(I don't recall which) by 40% at launch but I don't see how they could have made into the production without having performance advantage.
I also think that one piece carbon fiber driveshaft provides better throttle response than the traditional two-piece steel shaft. Not that there was anything wrong with the steel shafts that M3s used for generations. I remember one of the reasons Honda S2000 is regarded as having a great input response is the one-piece driveshaft.
Pass me if you can.
g80
