08-24-2020, 04:45 PM | #1 |
REP 5,555
Porsche dealership reset my check engine light without fixing anything
Funny story, brought the car to dealership with check engine light that was an emissions issue. Dealer reset the light and told me to pick up the car. I called Porsche of America to complain, they said there is nothing they can do because there is no light so there is nothing to diagnose. WTF? What kind of service is this lol
08-24-2020, 06:00 PM | #3 |
REP 7,561
The door sill plate from my GLC300 fell off. When the car was in for service, I asked them to glue it back on. SM says they can't do that, I'd need to buy a new one and it isn't covered by the CPO warranty. I asked him how they would attach the new one. He says, "We just glue it on."
WTF??
08-24-2020, 06:13 PM | #4 | |
Space Force - 4 Star General
11,508
REP 3,265
What exactly was your complaint? That they didn't replace some physical part? Do you call up Apple to complain when your iPhone locks up and you have to power it off and back on to fix it? |
08-24-2020, 06:14 PM | #5 | |
REP 658
2005 Phoenix Yellow E46 M3 6MT Coupe
2007 Imola Red Z4 M Coupe 2013 Interlagos Blue E92 M3 6MT ZCP CF roof |
BimmerDimmer61473.00 XMetal1248.00 |
08-24-2020, 07:35 PM | #6 |
REP 757
$15 Bluetooth Dongle that in connection with an app, will read any code that pops up, usually with an option to reset most codes.
That said... A dealer should not be resetting a code without addressing what caused it. Doesn't matter what it is, codes don't pop up for no reason. The code is in all probability still stored where the dealer can access it (History) and or they probably have it and can provide a printout based upon your Vin! This is a non negotiable item, and the dealer would be hearing quite a lot of bitching on my part until rectified! Crazy... |
08-24-2020, 07:54 PM | #7 |
11,508
REP 3,265
08-24-2020, 08:13 PM | #8 |
REP 7,561
I've bought 7 cars from them. That should count for something. And I would have paid them the labor to glue it back on. I just don't see the need to buy an entirely new piece when the one I have is fine.
MKSixer34166.00 |
08-24-2020, 09:37 PM | #10 | |
REP 5,555
When car is under warranty and check engine comes up, dealer supposed to fix the car, not reset the light |
08-24-2020, 10:11 PM | #11 |
11,508
REP 3,265
08-24-2020, 10:36 PM | #12 | ||
11,508
REP 3,265
But based on your other post just now, where you elaborated that this has happened multiple times, it does seem there's a part they need to address. |
08-24-2020, 11:42 PM | #13 | |
REP 5,555
08-24-2020, 11:45 PM | #14 |
REP 3,002
I had a fluke code come up twice without a clear reason, then go away after a stop/start.
My dealership swore up and down that unless the CEL was actually showing/active, they had no way to go back into memory to see what happened. I can't really believe that this could be true, can it? |
08-25-2020, 12:39 AM | #15 | ||
11,508
REP 3,265
Anyway, I hope you get your P car fixed. If that light has now come on multiple times despite a reset, I agree, there is a physical error there that should be addressed. Good luck. |
08-25-2020, 02:20 AM | #16 |
2JZ-GTE
3,188
REP 4,174
Maybe they thought you were not technical. If the gas cap isn't on right it throws a code. I'm sure they documented the code.
08-25-2020, 12:47 PM | #17 |
REP 1,031
Drives: Like a bat out of hell.
Wait until your warranty runs out and see how eager they are to repair your car.
08-25-2020, 01:49 PM | #18 |
REP 3,853
do you drive your Porsche often or just once every 7-10 days ? If its a once a week car do you keep it on a battery tender?
My 458 would throw fluke codes all the time if I didn't drive it often or let it sit off the battery tender for long periods. you could always just buy a $10 code reader from Walmart and read/clear codes yourself too |
08-25-2020, 02:01 PM | #19 |
REP 3,666
That's not how dealerships work though. Every "job" for the car is documented in work orders/instructions and the glue most likely comes with the part. The job is going to be "replace" the part, which is why they'd be ordering it. There is likely no porsche task for "repair the glue".
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
F32Fleet3938.50 |
08-25-2020, 02:51 PM | #20 |
REP 426
More reason to DIY or develop a relationship with an enthusiast-driven independent.
Imagine if we had to drop off our significant others for service.
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick 2016 Agate Grey GT4 PCCB LWB 2013 HP4 Competition |
08-25-2020, 03:44 PM | #21 | |
REP 918
If they installed a plate with incorrect/misleading info on it they might be liable to damages based on the incorrect info.
08-26-2020, 05:20 PM | #22 |
REP 5,555
Well i had no choice but to pick up the car. Its hard to argue when dealer says we can't diagnose the fault because we already reset ECU even though they know exactly what need to be replaced.....Will have to wait till it comes up again and I am sure it will but could take months with covid in place. Some weeks I only drive once or twice
