08-26-2020, 01:51 AM | #1 |
2JZ-GTE
3174
Rep 4,149
Induction vs normal Electric range/cooktop
I don't have gas and I am going to replace the electric range in our kitchen. I see the induction ranges have come down in price. Anyone have or use them? How do they compare to regular electric ?
08-26-2020, 03:11 AM | #2 |
i'm just saying
6048
Rep 2,634
its more efficient clearly.. using it for quite some time now like the technology behind it..
a vid with an epic music..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
08-26-2020, 04:29 AM | #3 |
Rep 1,024
Don’t like them as much as gas, mostly due to the cooktop, but if all you have is electric in the space, I’d prefer them over regular electric. Much more efficient and you can better fine tune your temperature on the good ones. I have a portable induction that’s good for outdoor or tabletop use and it works well provided your pans work with them. Not all do..
08-26-2020, 05:34 AM | #5 | |
Rep 744
Isn't as impressive as a gas range appearance-wise, but every bit as capable for cooking, easier to clean, cooler in the kitchen (much cooler), and more efficient. If you're looking for functionality, Induction is the way to go. If you're building a showcase kitchen, gas looks spiffier (but is MUCH harder to keep clean). |
08-26-2020, 06:50 AM | #6 |
Rep 1,169
Drives: f83 / E93 335 / E70 X5 40d
We bought an induction stove 10 years ago and never looked back - won't ever go back to gas.
Here's why: 1. As already said, MUCH easier to keep clean - that's a slam dunk for my wife, who's a clean freak. 2. Safer 3. As controllable as gas, if not more so, when you get used to it. Only issue is that you need to buy induction friendly pots and pans. |
sygazelle14079.00 |
08-26-2020, 01:13 PM | #7 |
Rep 10,624
Reliability is hit or miss and IMO the use of buttons rather than knobs to control the field is a downer.
Some coils maintain temps by cycling the coil on/off and that is a turn off by some users. Also, coils used to shut off when a pan was raised off the cooktop. It's a PITA for people who toss. They're great a boiling liquids You can't use aluminum cookware because it's not magnetic. Cast iron can crack the cook top. They're expensive vs NatGas and normal electric.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
AlpineWhite_SJ1579.00 |
08-26-2020, 01:16 PM | #8 |
Rep 284
Yes - we have a Jenn-air induction cooktop, this model in fact:
It's amazing because as you can see it is completely flat - looks amazing. We love it - just make sure to also buy conductive cookware otherwise a stainless steel set won't work for example. As others have said - very easy to regulate temperature, and talk about bringing fluids to a boil fast! |
08-26-2020, 01:36 PM | #9 |
Rep 2,044
"Food cannot be charred
Food cannot be charred since there is no flame. For those wanting to roast peppers or marshmallows on a flame, induction cooktop is a setback." What does this mean? Can you char a steak in a cast iron pan, or roast up some onions & peppers in a pan nicely? Murf |
08-26-2020, 01:45 PM | #10 | |
Rep 284
So the short answer is yes, absolutely! - a cast iron pan will cook your steak (or other foods) beautifully on an induction cooktop and at very high temperature so you can create a solid char seal on the outside. But do I recommend that? No - because just as it would on a gas or electric stovetop, you'll also get a lot of smoke from this technique. And presumably this is inside your home, so why would you? In fact, I cook my steaks in my cast iron pan on my side burner of my grill outside. |
08-26-2020, 04:29 PM | #11 | |
Rep 1,024
I'd also recommend ensuring that at least one of the induction burners has high enough power to maintain high temps for searing or frying and look into what the recovery time is. Recovery is how quickly does your pan get back up to proper temp once food has been added. |
08-26-2020, 06:53 PM | #12 |
"Salud"
15250
Rep 4,971
Nothing and I mean nothing is a better option for cooking than GAS.
Take it from a practical Chef. |
Lucky John617.00 |
08-26-2020, 08:47 PM | #13 |
Rep 3,313
I had a similar thread a couple of years ago and went induction, it's 100 times better than gas for everything except the edges of a pan, like say an omelet.
Get one with knobs though, Fridgidair or Blue Star... touch panels suck arse. Old thread .... https://e84.xbimmers.com/forums/show....php?t=1592541 |
08-26-2020, 09:03 PM | #14 | |
Rep 1,024
08-26-2020, 10:05 PM | #15 | ||
Rep 744
Ours is now 3 years old, and has some small, very minor (<1cm) scratches!which can be seen up close, but looks great from 4-5 feet away. Our range is used multiple times each day, so it's definitely not a 'show' item (much like our BMW). |
08-26-2020, 11:14 PM | #16 | |
Rep 1,024
08-26-2020, 11:16 PM | #17 |
Rep 1,186
My wife thinks shes on top chef when she cooks and will beat the crap out of any induction cooktop.
Plus we use the wok a lot. For those reasons +1 for gas. |
AlpineWhite_SJ1579.00 eluded3174.00 |
08-27-2020, 07:39 AM | #19 | |
Rep 744
But, I'll take induction over gas for everything else. |
08-27-2020, 09:42 AM | #21 | |
Rep 744
Makes life much easier. |
vreihen1621622.50 |
08-27-2020, 09:45 AM | #22 |
Rep 1,186
