08-26-2020, 01:19 AM | #1 |
2676
Rep 61,008
Drives: BMW F82 M4, BMW WIDEBODY F13
ÖHLINS SUSPENSION l AUTHORIZED DEALER l AR MOTORWERKZ
Öhlins Racing has been an integrated part of the motorsport industry as well as the motorcycle and automotive industry for 40 years. Our focus has always been on high-quality products, service, and support all the way from the MotoGP circuits to the local, national racing events in over 50 distributing countries. Our passion for innovations and state-of-the-art technology motivates us to search for the next generation of advanced suspension technology. The Ohlins philosophy has always been to supply the aftermarket, OEM partners, and teams with high-end suspension technology, and we are all dedicated to exceeding our customer’s expectations throughout the world. Our dedicated and professional staff cooperates with some of the most prestigious manufacturers and teams in the world to find the optimal suspension performance. And in the end, this knowledge finds its way to the aftermarket and OEM shock absorbers, front forks and steering dampers on the street. No matter if it is a racing team or a passionate enthusiast rider in search of a better functioning suspension unit on his bike. ÖHLINS ROAD & TRAK SUSPENSION FOR BMW E46 M3 Backed by a 2-year limited warranty, Ohlins Road&Track is designed to improve the performance and comfort of your car. With Ohlins DNA integrated throughout, this suspension is the must-have upgrade for your automobile. AR Motorsports is a proud premier dealer of Ohlins high performing suspension kits. We are an authorized distributor and installer of Ohlins suspension components. Ohlins suspension components transform a vehicle’s performance more than any other modification, improving acceleration, handling, and braking in every condition and extremes. The R&T suspension fits the 3 Series, including the 128 and 135 models, transforming these achievers into overachievers in ride confidence and control. Cruising corners and carving curves have an equally enhanced feel with an Ohlins tuned suspension. The Struts have a single-bleed adjuster, preload adjuster (approximately 15mm lower than stock), coil spring with model-specific spring rate, and dust cover. Some applications include top mounts. Both front and rear components have Dual-Flow Valves (DFV)and are lightweight, corrosion-resistant, fully rebuildable for a lifetime of service, and come with a two-year limited warranty. FEATURES DFV (Dual Flow Valve) Adjustable ride-height Fully rebuildable Corrosion salt spray tested (ISO 9227) Includes hardware and installation instructions Can be used with OEM top mounts 2 Years limited warranty FRONT McPherson Strut Single bleed adjuster Spring preload adjuster (approx. 15 mm lower than standard) Coil Springs Dustcovers REAR Conventional Shock Absorber Single bleed adjuster Separate spring preload adjuster (approx. 15 mm lower than standard) Coil Springs Dustcovers Speak with our fitment specialists today! Experience the Ohlins performance and enjoy competitive deals with us at AR Motorwerkz CALL/TEXT- (866) 514-0058 EMAIL-info@armotorwerkz.com |
08-27-2020, 10:54 AM | #2 |
2676
Rep 61,008
OHLINS Suspension for BMW F87 M2 AR Motorwerkz carries out great deals as a premier dealer of OHLINS Suspension! Ask our fitment specialists all your OHLINS and other fitment questions! We got answers! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
08-30-2020, 07:50 PM | #3 |
2676
Rep 61,008
OHLINS TTX46 Suspension for BMW F82 M4 Get that GT Race feels when driving on TTX46 by OHLINS Suspension! Get the best of the best in every set of OHLINS from us at AR Motorwerkz CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
09-04-2020, 10:35 AM | #4 |
2676
Rep 61,008
OHLINS Suspension for BMW E46 M3 Our in-house fitment specialists can help you with all your OHLINS and other fitment needs at AR Motorwerkz CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 09-23-2020 at 01:24 AM.. |
09-09-2020, 10:59 AM | #5 |
2676
Rep 61,008
OHLINS Suspension for BMW E82 Chassis, applicable across all1-Series including the 1M Get that track-ready performance with OHLINS suspension from us at AR Motorwerkz! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 09-23-2020 at 01:25 AM.. |
to_riffic3029.00 |
09-12-2020, 09:50 PM | #6 |
2676
Rep 61,008
OHLINS for BMW F82 M4 Don’t miss out on all our competitive deals on OHLINS Suspension products at AR Motorwerkz! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 10-06-2020 at 10:59 AM.. |
09-15-2020, 10:31 AM | #7 |
2676
Rep 61,008
OHLINS Suspension for BMW E46 M3 We are an authorized dealer of OHLINS Suspension which means: ✅ competitive priring & ✅ fast turnaround time CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 10-06-2020 at 11:00 AM.. |
09-19-2020, 08:24 PM | #8 |
2676
Rep 61,008
OHLINS Suspension for BMW E82 135i Transform your daily drivers with one of the world’s most prestige suspension brands! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 09-23-2020 at 01:31 AM.. |
09-22-2020, 10:49 AM | #9 |
2676
Rep 61,008
OHLINS Suspension for BMW F87 M2 We got you covered with all your OHLINS and other fitment needs! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 10-06-2020 at 11:01 AM.. |
09-25-2020, 10:49 AM | #10 |
2676
Rep 61,008
OHLINS Suspension for BMW E92 M3 Get the best of the best in every set of OHLINS from us at AR Motorwerkz CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 10-06-2020 at 11:02 AM.. |
09-29-2020, 11:10 AM | #11 |
2676
Rep 61,008
OHLINS DFV Suspension on Eibach Springs Combo for BMW F87 M2 Let our great team of fitment experts help you with your suspension upgrade! We carry and trust OHLINS suspension in guaranteeing our client’s performance satisfaction! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-02-2020, 10:34 AM | #12 |
2676
Rep 61,008
OHLINS Suspension for BMW F87 M2 Enjoy track days with OHLINS Suspension without compromising your daily regular drive CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 10-06-2020 at 11:09 AM.. |
10-05-2020, 11:33 AM | #13 |
2676
Rep 61,008
OHLINS Suspension for BMW F87 M2 Enjoy track days with OHLINS Suspension without compromising your daily regular drive CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com Last edited by AR_Motorwerkz; 10-06-2020 at 11:11 AM.. |
10-09-2020, 04:33 PM | #14 |
2676
Rep 61,008
OHLINS Suspension for BMW E92 M3 We got all your favorite OHLINS suspension products available at the shop! Speak with our fitment specialists and let us help you get set up! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-12-2020, 05:18 PM | #15 |
2676
Rep 61,008
OHLINS Suspension for BMW F87 M2 Get that Undeniable handling excellence and incomparable performance in every set of OHLINS Suspension CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-16-2020, 05:26 PM | #16 |
2676
Rep 61,008
OHLINS Suspension for BMW F82 M4 Stop settling for less than PERFECT! Cop yourself a set of OHLINS Suspension now! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-19-2020, 04:14 PM | #17 |
2676
Rep 61,008
OHLINS Suspension for BMW E92 M3 Get competitive deals on OHLINS Suspension from us at AR Motorwerkz [B]CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-21-2020, 04:11 PM | #18 |
2676
Rep 61,008
OHLINS Suspension for BMW E82 Chassis, applicable across all 1-Series including the 1M Take advantage of our “Forum-members” only pricing on all sets of OHLINS suspension at AR Motorwerkz! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-23-2020, 04:19 PM | #19 |
2676
Rep 61,008
OHLINS Suspension for BMW F82 M4 Get the best of both worlds with OHLINS’ ROAD-&-TRACK Suspension! We got them all available at AR Motorwerkz! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-25-2020, 09:08 PM | #20 |
2676
Rep 61,008
OHLINS Suspension for BMW F87 M2 We carry nothing but the best brands for all your tuning and fitment needs like OHLINS CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
10-29-2020, 04:08 PM | #21 |
2676
Rep 61,008
OHLINS Suspension for BMW E82 135i From your daily to your weekend warrior, we want to help you with all your suspension builds! CALL/TEXT- (818) 588-5403 EMAIL-info@armotorwerkz.com |
11-13-2020, 02:51 PM | #22 |
2676
Rep 61,008
With OHLINS coilovers, you’ll transform your ride into a true race car! 🏎🏎🏎 CALL/TEXT- (866) 514-0058 EMAIL-info@armotorwerkz.com Picture below: BMW M2 racing with Ohlins Advanced Trackday coilovers |
