08-26-2020, 04:49 PM | #1 |
Rep 4
Tracking down grinding engine noise. Please help!!
This noise has been driving me crazy because both my mechanics and I cannot figure out what this noise is. Does anyone have any idea what it may be? It is much more noticeable when in cold weather when mildly accelerating (maybe around 3k rpms). Only noticeable when driving and you will not hear it when in park, neutral, or reverse. Please! Any ideas will help!! Last edited by N55benji; 08-26-2020 at 04:58 PM.. |
08-26-2020, 04:55 PM | #2 |
Rep 7,632
You need to provide more info. Does it happen the same in P/D/N? Or only when driving? RPM dependent or speed dependent? Any change depending on braking or accelerating versus coasting?
Read my post here and see if it might be the same thing, although it seems different. https://f30.bimmerpost.com/forums/sh....php?t=1708574 |
08-26-2020, 05:01 PM | #3 |
Rep 4
Sorry you're right, I forgot to add more info that would be helpful. It is much more noticeable when in cold weather and when mildly accelerating (maybe around 3k rpms). Only noticeable when driving and you will not hear it when in park, neutral, reverse, or when breaking. I also notice it more at lower speeds when I mildly accelerate.
08-26-2020, 05:23 PM | #4 | |
Rep 7,632
08-26-2020, 05:33 PM | #7 |
Rep 4
08-26-2020, 05:54 PM | #8 |
Rep 10,319
08-26-2020, 10:41 PM | #9 |
Car Hypochondriac
336
Rep 904
Drives: 2014 335i M-Sport Estoril Blue
Mine does this too, especially when the AC is on. I've just learned to live with it.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
08-27-2020, 12:02 AM | #10 |
Rep 7,632
08-27-2020, 01:24 PM | #11 |
Rep 5,393
Most likely something is loose in the area of the transmission tunnel or engine/transmission/exhaust mount is broken. The fact that it only does it under load makes me think it's a broken or failing mount. You'll need to get under the car to inspect.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
08-27-2020, 09:28 PM | #12 |
Car Hypochondriac
336
Rep 904
The one where they add the weight to that hose? It could be, mine is missing that weight.
08-27-2020, 10:45 PM | #13 |
Rep 7,632
Tags |
engine noise, f30, f30 engine, n55 |
