BMW E46 M3 - Legend Eternal
home
E46 M3 Coupe and Convertible Forum Photos, Videos, Builds
      09-04-2020, 06:20 PM   #1
Structure3230
Drives: 2013 BMW M5
Structure3230 Build & Track Vlog
Current Status:
Ohlins coilover suspension
Rear subframe reinforcement by TC Designs
Bayside Fabrication roll bar
Cobra Kevlar Seats
Schroth 6 point harnesses
Ground Control camber plates
Eisenmann sport exhaust
Rogue Engineering / CSF high performance radiator
Rogue Engineering / CSF high performance oil cooler
Rogue Engineering FCAB bushings
Rogue Engineering RTAB bushings
Rogue Engineering rear spring perch reinforcement
Rogue Engineering rear shock mount reinforcement
Rogue Engineering strut brace
Rogue Engineering differential bushings
Rogue Engineering high pressure coolant line
Rogue Engineering transmission mounts
Rogue Engineering front sway bar end links
Bimmerworld engine mounts
Bimmerworld front brake caliper brass bushing kit
PFC Direct Drive Rotors
PFC front & rear 01 brake pads
Bimmerworld rear brake caliper brass bushing kit
Brake fluid flush with Castrol React SRF
Stoptech SS brake lines
Turner Motorsports shifter rebuild kit
CARB legal K&N intake
Front & rear Hotchkis sway bar kit
BMW original parts complete water system refresh
BMW original parts complete clutch kit
BMW original parts oil filter housing
BMW original parts steering lines
BMW original parts guibo
BMW original parts transmission fluid
BMW original parts differential fluid
BMW original parts front wiper cowl
BMW original parts F10 M5 lighted shifter with merino leather
BMW original parts steering wheel reupholstered in alcantara and merino leather
BMW original IHKA relocation for Android navigation system
Upgraded sound system with focal speakers/crossovers, PPI amp, and Kicker 6X9 subwoofer in factory locations
BMW original subframe foam reinforcement performed at BMW of North America’s National Workshop
BMW original VANOS bolts preventive maintenance performed at BMW of North America’s National Workshop
      09-27-2020, 09:04 PM   #2
Structure3230
Drives: 2013 BMW M5
VLOG 002
      10-02-2020, 08:28 PM   #3
AR_Motorwerkz
AR_Motorwerkz's Avatar
Drives: BMW F82 M4, BMW WIDEBODY F13
Sick track build, bet she's a blast! 🔥
e46m3
