09-14-2020, 02:45 PM | #1 |
Rep 336
742M 22" Wheel weight
Does anyone know the weight of these?
In the time I've spent trying to find it online I could have just gone into the garage and pulled them off to check. Would like to know actual wheel weight though not wheel and tire. |
09-15-2020, 09:56 AM | #2 |
Rep 242
Heavy AF is all I can say. Take one off the back and you will see. They are definitely not forged.
09-15-2020, 12:07 PM | #3 |
Rep 5,742
Drives: '24 iX50; '23 i4 M50
I have an extra set of 742M I use for my winter setup sitting in my garage and I could always weigh one, then minus the 38lb (as per TR) Pirelli Winter tire to give you an idea if you were interested
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
scotchy210.00 |
09-15-2020, 12:09 PM | #4 |
Rep 336
If you could that would be awesome! Would love to know front and rear.
09-15-2020, 12:12 PM | #5 |
Rep 5,742
On it this weekend...according to TR, front Pirelli Winter is 33lbs
scotchy210.00 |
09-15-2020, 01:13 PM | #6 |
Rep 336
09-15-2020, 01:20 PM | #7 |
Rep 336
Thanks Kief. I didn't want to wait so pulled one off the front just now to check. According to my $25 WW scale, 73.4lbs with a Conti on it that is fairly worn. Even not taking into account the tire likely weighing at least a pound less than when new, that puts it at 41.4lbs for the front rim.
So the fronts are probably in the range of about 43lbs and rear probably 46ish. (Other staggered sets I've had are usually about 3lbs different front to rear) |
