09-16-2020, 06:41 PM | #1 |
Rep 682
Winter tire advice for M40i
Starting the search for winter tires and noticing alot of 18" packages with 60 series rubber. Any comments from owners with this setup? My car came with the 245 50 19s on the skinny 7.5 inch rims and no issues. Or do i ante up and stay with 50 series winter rubber on 19s? As well how obnoxious is the BMW warning if tpms not installed on the winter rims.. Thanks
09-16-2020, 07:32 PM | #2 |
Rep 1,097
Drives: 2021 X3 M40i
I read somewhere in this forum that 18 inch wheels do not clear the M40i brakes. So might need 19s.
09-16-2020, 08:06 PM | #3 |
Rep 1,044
BMW winter 18" packages will clear 30i calipers but not M40i calipers.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
09-16-2020, 09:18 PM | #4 |
Rep 13
TireRack has 18" winter wheel and tire packages available. I put 18" Michelin Pilot Alpin 5 ZP tires (run flats) on my M40i. No problems with the recommended package at all. There are eight different 18-inch winter tires and dozens of inexpensive wheels still available. I went the 18-inch route and saved thousands over the BMW OE route.
Alias1431799.50 |
09-21-2020, 02:01 PM | #7 |
Rep 79
I am about to order a set from Tire Rack. I specced my X3 with the 20" RFTs, but I want my winter wheels to be 19"
Can I just order a set of 19" wheels and winter tires from TireRack or do I have to do anything special to make the 19" set work since it's normally riding on 20"? |
09-21-2020, 02:08 PM | #8 |
Rep 50
I switched from OEM 19" to the OEM 20" with no problem. Tires need to be the same circumference. You just change the TPMS monitoring system to the different tire size. I have a set of 19" 698M wheels with all season Pirelli with 1,000 miles on them if you're interested.
09-21-2020, 08:18 PM | #9 |
Rep 9
THis is going to be my first winter in my M40i. It has the 21 inch wheels. Are you guys finding tire/wheel packages or tirerack (or similiar) that are cheaper than @ shopbmwusa? This package is 2.5k https://www.shopbmwusa.com/product/6...EEL---TIRE-SET
thanks |
09-21-2020, 11:54 PM | #10 | |
Rep 309
09-22-2020, 12:21 AM | #11 | |
Rep 1,097
09-25-2020, 03:33 PM | #12 |
Rep 590
I like the 695 black wheels with a 20" winter tire. I also like Nokian tires. But the only option for the 20" is the Hakka R3 which is 245/40x20. That's less than the original 245/45x20 that I would get with the X3. If I chose that tire, would the only issue be that the speedometer would read incorrectly? Can I in fact use that tire without screwing anything up?
09-25-2020, 05:41 PM | #13 | |
Rep 1,097
The other option is you can get a Blizzak or X-ICE instead of the Nokian in the OEM size. |
09-25-2020, 06:19 PM | #14 |
Rep 1,368
I priced out winter tires at my dealership today.
20 inch OEM rims with tires $5500 + tax 19 inch oem rims with tires $4500 + tax Installation still extra I believe, not sure what that charge is. I know they charge $250 to put rubber on rims. WTF? I thought spending anything over $2.5K was expensive, but these tires are stupidly expensive. I should have kept my Golf R for a few more years I think.... Rob |
09-25-2020, 09:19 PM | #16 | |
Rep 280
$5500 is quiet a steep price to pay for 20s but then again it OEM. I believe I was a little over $3000 installed for a set of 20" Hakka R3's on a beauitful set of MSW OZ wheels. |
09-25-2020, 09:54 PM | #17 | |
Rep 1,097
09-25-2020, 11:41 PM | #18 | |
Rep 1,368
Rob |
