09-17-2020, 10:53 PM | #1 |
Rep 27
E85 mix with JB4 Map5 N55
Hey guys I have the n55 and I'm running the Jb4 on my Activehybrid 3. I'm going to track it next week so I was thinking of mixing some e85 with my 93. I was curious how many gallons I could use and as to what mix to do 80-20, 70-30? Also what previous experiences have some of you guys had? Do I have to run map 5 for e85. Fairly new to this, My bolt ons are bms charge pipe and intake, CSF fmic, Wagner catless downpipe and the Jb4.
09-17-2020, 11:34 PM | #2 |
Rep 7,632
If you just want some extra octane for the track, it might be better to just add some race gas. If you are going to go the E85 route, you probably want to test your mix on the street first and make sure the car likes it before just going straight to the track... Ideally you also get a test kit and test your pump gas and E85 for ethanol content before you start mixing or you are completely guessing how much E% you will actually get in the tank... you can probably run anywhere from 2-4 gallons without a problem, but without knowing what is coming out of the pump, you really have no idea what you are getting in the tank.
09-18-2020, 04:03 PM | #3 | |
Rep 27
09-18-2020, 04:11 PM | #4 | |
Rep 7,632
09-18-2020, 05:26 PM | #6 |
Rep 7,632
A word of caution with this blanket statement - if your pump is 10% and your E85 is 85% (which is what my fuel here in California tests at), 5 gallons of E85 and the rest pump gas in a full tank will give an ethanol mix of 34% in the tank.
BM3 E30 OTS map map targets 16.6 psi of boost and just today a user posted logs with HPFP pressure dips with 15.5 psi of actual boost with an E30 mix. The OTS map is known to operate at the limit of the HPFP at this booth/ethanol level. IATs are another factor as lower IATs on a boost-based tune will exacerbate HPFP issues (more sense air). So, if with the JB4 you are going to be running near or above 15 psi of boost i would be cautious of going with 5 gallons of E85. This is particularly true if you are going to a track day and not doing logging/testing of how the car is responding. I would reiterate the importance of testing the fuel E% if you are not running an ethanol sensor. |
AH35094.00 |
09-21-2020, 03:28 PM | #8 | |
Rep 27
09-21-2020, 05:44 PM | #10 | |
Rep 7,632
AH35094.00 |
09-22-2020, 07:50 PM | #12 | |||
Rep 27
09-22-2020, 08:07 PM | #13 |
Rep 2,379
Map5...dont worry too much as it will adjust to the mixture. Not sure if Map5 will lower boost if HPFP is about to crash though......so add back 50% caution
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
AH35094.00 |
09-22-2020, 10:47 PM | #14 |
Rep 7,632
09-23-2020, 12:18 AM | #15 | |
Rep 27
Here are a few logs!? |
09-23-2020, 12:19 AM | #16 |
Rep 27
09-23-2020, 04:43 AM | #18 | |
Rep 27
Log 1600853717 Is that how you share them just to the public? Can you access it that way? Thanks in advance |
09-23-2020, 10:36 AM | #19 | ||
Rep 27
https://datazap.me/u/guizaredwin/dat...0&data=1-4 https://datazap.me/u/guizaredwin/log...0&data=1-4 Here is the links too both data logs. Sorry just getting used to this website. |
