E93 - Cluster replace
09-23-2020, 08:51 AM | #1 |
Rep 67
Hi guys,
I have been having this idea of replacing my cluster, as it is in miles and where I live everything is in milometers. What I thought is to get one that is in KM and to make one out of two. So to use actual gauges of one that I get and use board of my one, so it will keep the millage. Then I should do some calibration of the speedo maybe, I guess. Or this is not going to work this way? Thanks. |
09-23-2020, 09:34 AM | #2 |
Rep 4,330
contact venoxy
have them make gauge faces with whatever you want. swap the faces, check calibration and adjust with perfekt toolbox if needed. You can't swap any boards without setting the mileage tamper dot unless you have it virginized first so it appears as brand new to the car. this is now a good opportunity to change the mpg gauge to an oil temp gauge if that's something you'd like to do. not sure what the diesels got. |
