09-23-2020, 09:02 AM | #1 |
Rep 94
Required Alignment
I have a 2020 X3 M40i and the dealership told me at my first oil change that BMW requires every 10k miles for tire rotation and full alignment and that it would be an out of pocket charge as it was not covered by the maintenance plan.
I did not proceed as I was only at 8k miles but I have never seen anything about this so called "required maintenance" and seems to go against what my salesperson said when I purchased the car that any required maintenance work would be covered during my lease. Is everyone else doing this every 10k miles? I just have caught the dealership lying so many times I just do not trust anything they say anymore and come here to get the truth. |
09-23-2020, 09:07 AM | #2 |
Rep 4,107
Sounds like dealer BS to me but I'm new to the X3. Maybe freshxdough can chime in on this...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
09-23-2020, 09:31 AM | #3 |
Rep 1,389
I do the alignments every oil change. The camber is off on the G01 and the outside edge of my tires was wearing abnormally. It isn't technically required, but it was only $200 last trip and I felt it was well worth it.
2024 BMW XM
2023 Porsche Taycan Cross Turismo 4S 2023 BMW iX M60 (sold) 2020 Porsche Cayenne E Hybrid (sold) 2018 X3 M40i (sold) |
09-23-2020, 10:12 AM | #4 |
Rep 1,913
you should not need to align the car unless it's had suspension work performed or you did something like smacking a curb or hit major pothole, or you notice unusual tire wear pattern.
Been driving Bimmers for 15 years, only time any of my car's required alignment was after suspension component replacement work - Dealer advising regular alignments sounds like great money maker for them. |
09-23-2020, 10:19 AM | #6 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3566
Rep 4,249
Alignment and rotation is never required. But service advisors are sometimes forced by management to push things. Just like every time you go into target or JcPenny and they ask you if you want to open a credit card with them, they get spiffs on those types of things. I think the writers wording was poor, insinuating that it is "required". It is merely suggested.
Dealers do however 'recommend' a yearly alignment. An annual alignment helps with tire wear and keeps vehicle handling in check. It is a good idea to get one every year, especially with the M40i that likes to eat tires on the outer edges. Even if you haven't done any suspension work or hit any pot holes it does not take much to knock out the front toe and start eating tires. Rotation is obviously only available for those who have square setups and would not be a bad idea to rotate when doing an annual alignment to get the most tire life. |
drewfromthehou80.50 |
09-23-2020, 10:35 AM | #7 |
Rep 1,121
I checked the Owner's Maintenance Manual in my 2020 X3 and I found NO REFERENCE to "wheel alignments" at all....and certainly NOT as part of any scheduled maintenance. While not a terrible idea, IF one has more money than common sense, there's just no need if the car doesn't "pull" to one side or if the tires are wearing evenly.(especially when braking and not holding the steering wheel tightly).
Rotating tires at regular intervals IS a good idea to make them last a bit longer. I change my oil every 5,000 miles NOT every 10,000. My "indi" does every other change while my BMW does the other under the included factory maintenance. I have my "indi" rotate the tires because his labor rate is a fraction of the dealer. But, as I said, frequent wheel alignments are NOT suggest or required......If the car rides well, the only alignments I perform are when I put new tires on the car. |
09-23-2020, 11:46 AM | #8 |
Rep 1,046
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
There is no camber adjustment on a normal G01 alignment. All that is done is the toe adjustment.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
Wgosma810.50 |
09-23-2020, 12:13 PM | #9 | |
Rep 1,389
2024 BMW XM
09-23-2020, 12:54 PM | #10 | |
Rep 1,046
09-23-2020, 02:13 PM | #11 |
Rep 312
Drives: 2019 x3 M40i
FxD said it best, not required but some push it hard. that said, get an alignment for peace of mind early on. Mine was way off from spec from the factory and ate my oem tires super fast. They wouldn't cover it saying I knocked the alignment out, BS. got the alignment and been much rougher in the following 18 months and no issues yet. If mine is out from the factory might be worth getting it looked at. but a local shop would be cheaper than BMW
2019 X3 M40i - Phytonic Blue - MST Intake, VRSF Chargepipe, ER catted/coated DP, Dorch Stage 2 HPFP, BM3 stage 2+ e30, XHP stage 3, 275/40/20 Michelin MPS4
09-23-2020, 03:18 PM | #12 | |
3566
Rep 4,249
09-23-2020, 03:26 PM | #13 |
Rep 312
no front camber? interesting, not even a lobed strut bolt? good to know. thanks.
09-23-2020, 03:29 PM | #14 |
3566
Rep 4,249
Front camber is fixed in place. Swivel bearings can be replaced in the Plus or Minus camber direction to correct camber if needed.
09-23-2020, 04:14 PM | #15 |
Rep 682
Ive never aligned 01 330i or 07 Z4M- however my M40i steering wheel has been cocked a tiny increment to the left on delivery. Would you have dealer adjust and how ?or leave alone?
09-23-2020, 04:49 PM | #16 | |
Rep 94
However the cost was 360 dollars, so I guess that is reasonable to avoid having to replace the 21" tires early. I'm learning a lot about my BMW on these forums and most of it from you freshdough! So much appreciated! |
freshxdough3565.50 |
09-23-2020, 05:31 PM | #17 |
Rep 1,121
No matter if it's "suggested", "advised", "wise" or anything else...there's NO MENTION of it in the BMW "Maintenance Schedule" book that comes with the car. So it's certainly not "required" as one was told and it has no effect on the warranty whatsoever.
Is it still a good idea?.....if there are no symptoms then why throw away money? As I wrote before, most will advise an alignment be performed when new tires are installed. A car that's out of alignment is one of the easiest tests to perform as a driver......if it pulls to one side when braking on a flat road or the tires are wearing down noticeably on an edge....then get the alignment checked....if not save your money. |
drewfromthehou80.50 Wgosma810.50 |
09-23-2020, 06:17 PM | #18 |
Rep 7
A suspension that requires an alignment every 10K is poorly designed. Never had to do this in 45 yrs owning BMWs, Audis, Volvos and even Ramblers. If you hit something, or replace suspension components, then get the alignment. If X3's are eating tires, that's not a great design (but no car is perfect).
09-23-2020, 07:35 PM | #19 |
Rep 3,957
So since I have the 20" wheels on my M40i, is it ok to move the left side wheels to the right and vice versa?
09-23-2020, 07:47 PM | #20 |
Rep 1,097
Drives: 2021 X3 M40i
09-24-2020, 10:05 AM | #22 |
Rep 1,046
Have the dealer adjust the toe. If the tires are wearing evenly, it would take 3 minutes to do it yourself with only a couple of wrenches.
