09-24-2020, 11:24 AM | #1 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
G82 M4 Power to Weight Ratio & Performance Discussion Official Thread
Here are some preliminary numbers that I pulled off BMW's website in an attempt to have a thoughtful discussion on the weight of the vehicle, which we all hate, but in the context of the engineering improvements.
Would appreciate some source checking but compared an F82 M4C RWD DCT compared to a G82 M4C RWD 8AT. While the sticker of the weight is huge...the relative increase in power makes up for it and is pretty impressive considering dynos have confirmed S58 to be even higher output in the X3M. I'm impressed that the G82 is pushing ratios close to a 718 GT4....can't wait to see the Nordschleife lap times. Last edited by Avaley; 10-25-2020 at 11:39 AM.. |
09-24-2020, 12:22 PM | #2 |
Barge driver
8676
Rep 12,431
I don't think your weights are correct for the F82 the F80 was 1635kg EU or 3597lbs the M4 was lighter than that.
Looking at BMW blogs numbers there is hardly any difference in the power/weight ratio: F80 DCT Comp = 450hp/1635kg = 275hp/tonne G80 DCT Comp = 510hp/1805kg = 282hp/tonne
730d/Z4C
09-24-2020, 12:55 PM | #4 |
Rep 7,037
F8X Competition wasn’t available at launch so many of us are at 425hp...
80 hp bump and 200 extra lbs. very similar to E46 vs E92. Last edited by solstice; 09-24-2020 at 01:00 PM.. |
09-24-2020, 01:12 PM | #5 | |
Rep 636
https://www.bmwusa.com/vehicles/4-se...-features.html |
09-24-2020, 01:16 PM | #6 | |
Rep 7,037
09-24-2020, 01:26 PM | #7 |
Rep 636
https://x3.xbimmers.com/forums/showthread.php?t=1638381
Says 491 at the wheel on 89 octane for S58 X3M. https://f80.bimmerpost.com/forums/sh....php?t=1023743 https://f80.bimmerpost.com/forums/sh....php?t=1249883 Says 425 at the wheel 93 octane on a 2015 F80 M3 and 400 wheel, some inconsistencies on S55 dynos (someone please confirm a better source as these were the quickest ones I could find). Bootmod3 says will do 500 with a tune. https://www.protuningfreaks.com/prod...-m2competition This is before the huge headroom in the S58 with a simple ECU tune to push it to 600whp...same tune from PTF for the S58. https://www.protuningfreaks.com/coll...mpetition-tune |
09-24-2020, 01:31 PM | #8 | |
Rep 7,037
Avaley735.00 |
09-24-2020, 01:42 PM | #9 |
Rep 2,956
The S58 is a big leap over the S55. It's a shame that the grille has taken all the attention because it's the engine that's going to make these cars special.
09-24-2020, 02:05 PM | #10 | |
Rep 636
Function > Form... i'm okay with the grille if it's aerodynamics and cooling are an improvement (which I presume is factual and obvious) and keeps IAT temps down. |
09-24-2020, 02:35 PM | #11 | |
///M Powered for Life
11500
Rep 10,333
I really don't care how it looks. Bigger grill = more air for cooling. And then complaints about a 3900lb car... and comments that instead they will get a 4400lb car because logic
NorCalAthlete3195.00 flanast148.50 |
09-24-2020, 02:53 PM | #12 |
Rep 6,926
09-24-2020, 02:55 PM | #13 |
Rep 6,926
More airflow is BS. The entire middle of the grill is blocked off, just like a normal bumper would be. It is basically traditional upper and lower grill sets, made to look like massive kidneys.
09-24-2020, 02:57 PM | #14 |
Rep 636
09-25-2020, 04:02 AM | #15 | |
Barge driver
8676
Rep 12,431
730d/Z4C
09-25-2020, 04:48 AM | #16 |
Rep 389
Drives: 18 BMW M2LPower
maybe M2 is going to be the new M4, F82 dimensions are OK.
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
09-25-2020, 06:56 PM | #18 |
Bored at work....
891
Rep 5,393
But we can’t tune the S58 in the G8x ....
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
09-25-2020, 08:29 PM | #19 |
2681
Rep 61,036
Drives: BMW F82 M4, BMW WIDEBODY F13
09-26-2020, 06:44 PM | #20 |
Rep 13,139
Two quotes from Colin Chapman:
"Simplify, then add lightness." "Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
///M is art ↔ Artemis
9
09-30-2020, 08:00 AM | #21 | |
Rep 20,742
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
09-30-2020, 08:10 AM | #22 |
Rep 20,742
A few more data points, AM&S weighed their loaded M4C LCI at 1,644kg (3,624lbs) and Autobild their M4cs at 1,602kg (3,532lb), which yields the following power-to-weight ratios:
So given these data points, the G82C has a 5.7% advantage over the F82C and 1.0% over the M4cs, while the F82 M4cs has a 4.7% advantage over the F82 M4C. A 5.7% advantage is nothing to skuf at, but 1.0% is not enough to entice me to move.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 09-30-2020 at 09:58 PM.. |
Wills28675.50 |
Tags |
bmw m4, g82, nurburgring, performance, power, ratio, s58, torque, track, tuning |
