N54: Where's this leak?
09-25-2020, 11:49 PM | #1 |
Rep 6
Hi all. Can smell oil burning once my 2008 335xi gets hot. Leak seems to be coming from left lower rear of engine when facing from the front. A couple of not-so-great pics. Can anyone identify the source of the leak, or tell me most likely spot to look? TIA
09-26-2020, 01:41 AM | #2 |
Rep 2,476
Most likely in that area would be the valve cover gasket, but it doesn't appear so in your photos - typically you'd see it all along that side of the cover. Maybe yours is leaking further back, or it could be rear turbo oil lines.
NLDoc6.00 |
09-26-2020, 02:32 AM | #3 |
Rep 5,443
Drives: Beige G31 40ix m sport
Try cleaning the area up with engine degreaser, you'll then have a better chance of seeing where it's coming from.
I would say vcg, if you notice fresh oil on the heat shield then it'll definitely be vcg.
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
NLDoc6.00 |
09-26-2020, 06:54 AM | #4 |
Rep 1,200
Probably VCG leaking in the rear of the head causing oil to leak onto the cats and burn off. That was the case with mine and I had smoke in the same area
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
NLDoc6.00 |
