09-26-2020, 11:23 PM | #1 |
Rep 439
Drives: 2016 M235i Xdrive 8A
Check Tire Pressure Warning
Hey folks- a few weeks ago I had my right rear tire patched by some shady local shop in a pinch.
Turns out they only plugged it, I was green at the time and didnt know the difference between a patch. At any rate, every day since then when I start the car the warning message to check tire pressure comes on. No matter how many times I reset it or let the system read the pressures, it always does this. Tire pressure is totally fine. No actual issues with the tire. Any ideas?
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
09-27-2020, 11:16 AM | #2 | |
Rep 5,262
OldCrow7xx72.50 |
09-30-2020, 05:18 PM | #3 |
Rep 6,833
If the tire is holding air and you are sure that it is at the correct pressure, my guess would be sensor damage as well.
-Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
OldCrow7xx72.50 |
10-07-2020, 03:27 PM | #4 |
Rep 439
Is it safe to do a short burnout and 1/8th mile pull on a patched tire? I feel like the heat and friction could open up the wound- but maybe the vulcan process holds harder than I realize?
10-07-2020, 04:45 PM | #5 | |
Rep 5,580
Not sure I'd be pulling high G's on the Daytona banking but anything you can give it in the road will be within the patches capability. Plug is totally different. |
10-07-2020, 05:18 PM | #6 | |
Rep 6,833
-Tom
10-07-2020, 09:39 PM | #7 | ||
Rep 439
For the record the tire is plugged and not patched, I didn't know there was a difference at time of repair. The sketchy meth head at the shop assured me I could still drift and slide the tire, but I trust the heads on this forum way more!
10-07-2020, 09:41 PM | #8 | ||
Rep 439
10-08-2020, 10:16 AM | #9 |
Rep 3,506
Don't forget to post your results.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
10-08-2020, 11:04 AM | #10 | |
Rep 439
