09-29-2020, 01:37 AM | #1 |
Rep 373
CSF cooler and ER cp
im having a massive head ache with my CSF cooler and ER charge pipe. i have probably had a boost leak for 2 years now but only noticed it with the custom Jordan tune loosing 5 psi.
i cannot get the bottom half of the cp to line up with the top the angle is completely different and if i do align them then the cp has to sit at an angle from the cooler which creates a leak. is there any other cp one would recommend?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
09-29-2020, 07:16 AM | #2 |
Rep 66
Not sure whats going with the top side with just that one ☝️ picture. Would help to see. Otherwise worse comes to worse cut your current charge pipe in the middle and add a quality silicone boot and it'll give you more flex in your charge pipe. But that's a last resort measure to save money. Prior to Try loosening all bolts and play around with all the pieces loose and try one more to also make sure the o-ring is still good and hasn't been pinched.
remove the upper clip on the charge pipe and Try locking the bottom in place first. Then push it all up and lock the upper
15 Estoril/Coral 435i coupe M-sport
96 Estoril/M-Cross M3 coupe 85 Delphin/Comfort 318i coupe |
09-29-2020, 09:54 AM | #3 |
Rep 4,216
FTP charge pipe - or try a suggestion from the other thread.
Personally, I would just spring for the new CP and sell the current.
Mods: Yes.
09-29-2020, 10:00 AM | #4 |
BimmerPost Supporting Vendor
24486
Rep 191,471
Its a very tight fit with CSF FMIC and ER charge pipe
Its best to use the Active Autowerke or FTP CP or get the Evolution Racewerks intercooler instead
09-29-2020, 11:06 AM | #5 |
Rep 7,632
That's a massive amount of oil coming out of our CP... did you add oil to the Oring or is that all blowby/PCV?
As far as the fitment goes, i would try a larger Oring first. Even if the bottom (IC side) of the CP is at a slightly angle, if the Oring is big enough and the clip is fully engaged you should not have a leak. You should also install the bottom first and use the maximum length of the coupler to minimize the angle at the bottom. A longer coupler may also solve your problem, perhaps one with a 45 deg angle. See the Oring thread for Oring sizes |
09-29-2020, 12:14 PM | #6 |
Rep 4,380
before shelling out for a new cp. i'd look at an offset or 22 degree elbow silicone coupler. there's numerous iterations offered, some with varying diameters. if necessary, cut the excess with a razor knife following a tape line.
as others have mentioned you ought to replace the o-rings, since they are likely damaged. lastly, you may want to consider gettng an oil catch can. Last edited by alohasurftoad; 09-29-2020 at 12:28 PM.. |
09-29-2020, 12:25 PM | #7 | |
Rep 932
alohasurftoad3132.00 |
09-30-2020, 09:12 AM | #8 | |
24486
Rep 191,471
10-01-2020, 09:12 AM | #9 |
Rep 373
thanks for the response i have bought that 22 degree silicone hose will be fitting it on the weekend
10-03-2020, 10:58 AM | #10 |
24486
Rep 191,471
10-07-2020, 03:23 PM | #11 |
No 55mph
1623
Rep 8,479
ER CP works/fits perfectly with my AA FMIC
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-07-2020, 04:17 PM | #12 |
24486
Rep 191,471
10-08-2020, 01:07 PM | #13 |
Rep 5,393
I'd be quite concerned about all that oil if it truly is coming out of the CP/IC. That's not normal.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
10-13-2020, 10:41 PM | #15 | ||
Rep 3,958
10-14-2020, 08:02 PM | #16 |
Rep 932
11-02-2020, 03:33 AM | #18 | |
Rep 3
I am having the same issues with my CSF. I've taken some measurements compared to OEM and think I have found the issue. I'm in contact with them now so will let you know what I find
11-02-2020, 10:13 AM | #19 |
24486
Rep 191,471
11-02-2020, 01:25 PM | #20 | |
Rep 77
F31 328i xDrive, EBII
11-10-2020, 05:27 PM | #21 | |
Rep 4,216
Mods: Yes.
ktw54.50 |
11-16-2020, 08:44 AM | #22 | |
Rep 3
My CSF cooler is making the OEM turbo pipe sit on the following angle; Seems similar to ChristosD issue |
ktw54.50 |
