09-30-2020, 10:53 PM | #1 |
Rep 155
Oil leak has me stumped.
Have a oil leak that has stumped me (I'm an enthusiast that does dyi and not a tech).
-'14 335i 56k miles. -oil pan gasket and oil housing gasket changed 1.5 year ago. -I do smell oil when turn on/off car. (Makes me think valve cover) -zero oil on ground, but some on the small skid plate that's sits behind the large belly cover/tray. -have been watching it for a couple days, and was hoping to get confirmation today by using my dye and black light. Wasn't not able to find anything definitive after warming up engine twice and watching for leaks above and under the car. (I'm going to try and clean everything I can and watch again). -oil still measures full according to computer after 2000 miles and one track day. -I see a drop here and a drop there, but nothing major. I want to figure this out, so I'm not just throwing wasted time and money. Any input appreciated and thoughts appreciated! |
10-01-2020, 07:27 AM | #3 |
Rep 67
If you take off the under tray and its a bit of oil leaking from the front passenger side could be a seal on your turbo is going bad as well. Had this happen to me on my stock turbo couple months back.
10-01-2020, 07:32 AM | #4 |
Rep 155
There is a tiny bit in that silver shield/pan on passenger side next to valve cover. No standing oil at any time, but there is evidence of oil there. Maybe if I put a small piece of sheet metal in that trough towards the back and see if it pools any oil? Maybe that would help:
10-01-2020, 07:34 AM | #5 | |
Rep 155
-What all did you have to do and pay to fix? - and how did you know for sure it was turbo? |
10-01-2020, 07:48 AM | #6 | |
Rep 67
I first came out to oil on the ground thought it was the oil pan but couldn't have been I just done it in march. But they got the car up on a lift and checked around seen that in the middle of the cold & hot side of the turbo it was leaking right from the turbo indicating the seals are going bad. I ended up just doing a turbo upgrade because I was going to anyways. |
10-01-2020, 04:06 PM | #7 |
Rep 10,394
Valve cover. Passenger side look for staining OR leaks. Especially towards the back side of the engine.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-01-2020, 07:48 PM | #8 |
Rep 155
There is some staining, but I haven't seen anything that would cause droplets. Maybe tiny seepage over time? I'm just tired of the oil smell in the cabin.
10-01-2020, 09:27 PM | #9 | |
Rep 10,394
10-02-2020, 11:23 AM | #10 |
Rep 63
+1 for VCG. Mine was replaced around 62k and the leak looked very similar to what you're seeing.
2014 335i M-Sport, CTS intake, VRSF FMIC, VRSF CP, BM3 stage 1
10-02-2020, 03:08 PM | #11 |
Rep 155
I may have two battles to work on. 😡Here are some pics that I observed. 1) is rear of engine, dripping from around the exhaust manifold. I'm guessing it came from rear of valve cover. 2) front of engine, looking like maybe coming from filler cap?
10-03-2020, 09:32 AM | #13 | |
Rep 10,394
Oil filter caps don't really develop leaks. Q: Did you use a genuine BMW gasket on the OFHG repair? Did you also replace the oil cooler gasket? I would look in those areas.
Brotherhef48.00 |
10-03-2020, 02:43 PM | #14 |
Rep 155
[/QUOTE]
VCG isn't really serious. A leak around the OFH is serious in the sense that if sufficient oil lands on the belt it'll slip off and can get ingested into the engine via front crank seal. You don't want that! Oil filter caps don't really develop leaks. Q: Did you use a genuine BMW gasket on the OFHG repair? Did you also replace the oil cooler gasket? I would look in those areas.[/QUOTE] Appreciate the info. I did not change oil cooler gasket and I believe I used oe gasket. I normally do. I'll look there some. |
10-04-2020, 09:43 AM | #15 |
Rep 841
Drives: Bmw 335i f30 N55 ( sold)
I also replaced VC around 70k under warranty
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
