10-02-2020, 02:51 PM | #1 |
Rep 324
Dorch stg1 hpfp enough?
So I have researched and searched the forums and I can't find a diffinitive answer. I'm looking to run a e30-e50 mix with a ps2 on my car and reach that 500+ whp number.
Can a dorch stg1 hpfp move enough fuel or will I need a stg2 hpfp? Can anyone with personal experience with dorch hpfp and a ps2 please share your experience. From what I have gathered I should be towards the max capabilities of the dorch stg1 hpfp with that amount of ethanol but that's just on paper no actual testing. Any help will be appreciated. |
10-02-2020, 03:00 PM | #2 |
Rep 3,715
For an Emix and PS2 I'd go Stage 2. If sticking with pump gas, Stage 1 would be enough.
My Stage 1 Dorch with Dinan turbo and E47 dyno'ed 15whp less than a PS2/XDI-35 M2 with PureBoost 93 octane custom tune (same dyno, same day), and I get HPFP dips if I increase the Emix above 55-60% or go >23-psi. And, that's in summertime, the dips would be worse in winter. There were no power gains taking my Dinan turbo above E50 or up to 23-psi, so I'm not worried about needing a Stage 2 Dorch, but you'll be flowing a decent bit more ethanol with the PS2 maxed out so I don't think Dorch Stage 1 will be enough. Last edited by ZM2; 10-02-2020 at 03:05 PM.. |
Bowenpuref3p92.50 |
10-02-2020, 03:16 PM | #3 | |
Rep 324
ZM22839.50 |
10-02-2020, 06:33 PM | #4 |
Rep 7,632
+1 for stage 2. Even if stage 1 can be enough, why set yourself up to operate right on the limit of hardware and have to worry about HPFP crash all over again?
Bowenpuref3p92.50 |
10-02-2020, 07:33 PM | #5 |
Car Hypochondriac
336
Rep 904
Drives: 2014 335i M-Sport Estoril Blue
I mean... the guy at the shop I go to said he was making 600whp with e50 and a XDI-35. My understanding was that is pushing the limits of the engine and driveline right? I personally would rather I limit myself to a level where I won't break shit.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
10-02-2020, 07:48 PM | #6 |
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
Spool FX150 seems like the best option IMO unless you plan on going big turbo...as we all know it's been proven with success running E85....
Bowenpuref3p92.50 |
10-02-2020, 08:27 PM | #7 | |
Rep 3,715
Haven’t seen anyone pushing 600whp on an xdi-35, much less with an EMix, especially when it flows even less than a Dorch Stage 1. But, please prove us wrong. Last edited by ZM2; 10-02-2020 at 08:35 PM.. |
10-02-2020, 08:31 PM | #8 |
Rep 3,715
Over on the M2 forum folks have been happier with Dorch customer service vs Spool. Not voting one over the other, just saying, and anytime I emailed Dorch they got back to me in <20min.
10-02-2020, 09:17 PM | #9 |
Rep 1,288
FX150 supplys almost as much as the Dorch 2.... shouldn't really need customer service... BM3 select original... MHD not sure yet... but I planned on getting a custom tune full E85 tune with MHD which the tuner has already done JerryBMW... so not worried about customer service... The shop I might be going to has already done them but it's a little far... checking monday the shop closer to me...
10-02-2020, 09:27 PM | #10 |
Rep 324
Yeah that's true honestly that's what dorch themselves recommended when I emailed them with the same question. But I figured I would look for some opions of those who have used dorch stg1 hpfp since they are not the ones trying to sell me the part.
10-02-2020, 09:29 PM | #11 | |
Rep 324
Unless anyone knows for sure I can click the dorch or xdi option on MHD and it will work with spools hpfp. |
10-02-2020, 09:42 PM | #12 | |
Rep 3,715
10-02-2020, 09:44 PM | #13 | |
Rep 3,715
10-02-2020, 10:44 PM | #14 |
Rep 1,288
10-02-2020, 10:49 PM | #15 | |
Rep 1,288
10-02-2020, 11:04 PM | #16 |
Rep 18
I was able to squeeze 495hp with the dorch stage 1 on e30 with a speedtech 8374 before i hit hpfp drops. Their customer service is top notch! Over nighted a new low pressure fuel line. Best customer service ive dealt with by far!
ZM22839.50 Bowenpuref3p92.50 |
10-02-2020, 11:35 PM | #17 |
Rep 1,288
If customer service is that important to you then that's your prerogative ... going by the numbers...
HDP5 (Stock N55).................0.837 HDP5 Evo (Stock B58)...........0.897 HDP6 (Stock B58TU).............1.107 Dorch Engineering Stage 1.....1.221....$1199 Spool fx150.........................1.340....$1399 Dorch Engineering Stage 2.....1.465....$1699 Spool fx180.........................1.600....$1799 Good luck in your decision... I'm sure you'll be happy with whatever you get... |
Bowenpuref3p92.50 |
10-02-2020, 11:51 PM | #18 |
Rep 3,715
Sure, I’ll drop >$1k on something that bolts to my engine as a critical fuel supply part, and rely on numbers vs customer service.
Makes a ton of sense. |
10-02-2020, 11:54 PM | #19 |
Rep 3,715
10-02-2020, 11:59 PM | #20 |
Rep 1,288
10-03-2020, 12:11 AM | #21 | |
Rep 1,288
"Slowspeed" on you tube went BigTurbo and FX150 and didn't know the BM3 option to pick at the time and thought it was the pump... he called spool and they sent him a brand new one...come to find out it was the "BM3 Original" box he had to pick and not the pump... I feel your over exaggerating this whole customer service thing... So far the FX150 handle everything he could throw at it with the Big Turbo (28lbs boost/ E65)... to each their own... also check out the MHD thread on why he picked MHD over BM3 I just loaded up... very interesting.... Last edited by FastF30; 10-03-2020 at 12:41 AM.. |
10-03-2020, 07:24 AM | #22 |
Rep 4,216
