10-06-2020, 06:37 PM | #1 |
Rep 157
Drives: X7_M50d(2020), X5_30d(2015)
TV tuner
Hi,
should TV tuner be able to work even during drive? (up to some reasonable speed) Obviously not via front screen but i don't see a problem for a (rear) entertainment system. The reason i'm asking is that my TV loses signal during drive so much that it's basically useless. And does somebody know if there is a way how to change EPG charset for TV tuner? Unfortunately i'm not sure about the first problem but after update to 07/2020.35, basically every special character in EPG is replaced by something else which makes it almost unreadable. And i would bet the TV channel change was faster before update, therefore i'm wondering if the update didn't screw up signal as well. I checked CAFD options for TV but found only region settings which is set ok. Thanks for any help! |
