BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > Upgrading M140i/M240i to Akebono Ceramic Pads
      10-07-2020, 07:13 PM   #1
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
Upgrading to ceramic pads on a BMW M140i/M240i is reasonably straightforward:
  1. Loosen the brake fluid cap.​
  2. Use a tool for the BMW lifting points to save damage.​
  3. Use a 1/8" x 8" punch to drive out the guides holding the anti-rattle springs and pads in place. Replace these if older than 40,000 kms.​
  4. Use moly pad goo on the backs of the pads where the pistons come into contact.​
  5. Replace the brake pad sensors on the left front and right back. These come with the Akebono kits (Front: EUR1880; Rear EUR1656 for M140i/M240i). Check realoem.com for your BMW model using the VIN.​
  6. Use a torque wrench to tighten the wheel nuts (140Nm).​
  7. Reset iDrive brake wear indicators by:
    a) pressing start button, no foot on brake;
    b) wait for Service reminder to disappear;
    c) press and hold the odometer button until you can see that values can change, and press until each of Front and Rear Brake values can be changed - it will show 'Reset possible' and will change to 'Reset?';
    d) press and hold until you see the resetting progress bar running and finish;
    e) press engine start button to close the process.​
  8. Bed in your new ceramic pads by some low and high speed stops, but not to a dead stop. Start with 60 kph, then work your way up to 100 kph. It will take some 500 Kms to fully bed the new pads in.
Comment: Step 7 is a necessary step as after reset the front indicator on my low kms M140i went from 70,000 kms to 90,000 kms. The rears changed by almost the same variance.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
1addicts
