10-10-2020, 12:29 PM | #1 |
Rep 23
BM3 Stage 2 Log Review, 14' 335i xDrive N55
2014 335i xDrive (N55). Stage 2 93 Agg.
MST Intake VRSF ChargePipe Wagner Tuning Comp 2 FMIC VRSF Catless Downpipe AWE Full Exhaust w/ Performance Midpipe NGK 97506 Plugs gapped at .022 How does this log look? https://www.bootmod3.net/log?id=5f7f...0b437a26c2efe7 |
10-11-2020, 08:58 PM | #3 |
Check out my Youtube @n55david!
1305
Rep 3,554
Drives: 2017 m240i, 2015 X3 x35i
looks fantastic cept where you go from 11 degrees of timing to like 9 then to like literally 0 then it comes back. super weird
I'm on my phone and can't see detail so great but I don't see knock, no fuel pressure dips. honestly other than that it looks practically perfect. you mixed some e85 in didn't you? you're afr says you may have . and what fuel pump are you running?
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
10-12-2020, 09:43 AM | #4 |
Rep 2,379
Why have you gapped the plugs?
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
10-12-2020, 11:30 AM | #6 |
Rep 7,632
Overall yes this log is really clean. Timing is great and indicates excellent fuel quality. I would say that boost does seem to drop quite a bit in the upper RPM... although most people dont rev all the way to 7k. Some drop in upper RPM is normal as the turbo can't keep up but i would take a look at a few other logs on the same map and see if people are holding more than ~13 psi to redline. WGDC is reasonably low though so that's good.
SFTFs are also quite positive, over 15% fuel added through most of the pull. So did you add ethanol to this tank or not? |
n55david1304.50 |
10-12-2020, 12:58 PM | #7 | |
Rep 23
10-12-2020, 01:05 PM | #8 | |
Rep 23
10-12-2020, 01:22 PM | #11 |
Rep 7,632
There's nothing inherently bad about STFT corrections, but +15% fuel is quite a bit of correction if you are just running pump gas. It basically means the tune is a little lean for whatever reason (or at least the DME thinks so based on O2 sensor readings) so it has to add that much fuel to reach AFR (lambda targets). I would just log again on the next tank of gas to see if maybe its a fluke. It could also be your intake, but you are maxing out MAF readings so its hard to say. Typical fuel STFTs are <5% with BM3 OTS maps running pump gas.
n55david1304.50 |
10-12-2020, 01:27 PM | #12 | |
Rep 23
10-12-2020, 02:05 PM | #13 |
Rep 7,632
If your DP is loose on the turbo side, yes, because you could have an exhaust leak before the O2 sensor and that could be throwing off AFRs. If its loose on the catback side (bottom), there's pretty much no way since that's pretty far downstream of the primary O2 sensor.
10-12-2020, 05:07 PM | #14 | |
Rep 23
10-12-2020, 05:12 PM | #15 | |
Rep 7,632
Your boost deviation in upper RPM just seemed a bit more than normal for EWG, although as i said some falloff is normal on stock turbo. I would check a few other BM3 logs running the same tune and see. You could also pressure test to confirm no leaks. |
10-12-2020, 09:03 PM | #17 |
Rep 7,632
Yes i know, that's exactly what i said in my post a couple above. The DME thinks its lean based on O2 sensor data, "so it has to add that much fuel to reach AFR (lambda targets)"
10-13-2020, 10:36 PM | #18 |
Rep 932
10-14-2020, 09:09 PM | #19 | |
Rep 2,379
(A Dane in China) |
10-15-2020, 12:03 PM | #20 | |
Rep 23
10-15-2020, 01:16 PM | #21 |
Rep 479
This log looks fantastic! Where in NY are based? Im in North Jersey right next to the city and myself and a few others are battling timing/knocking issues due to bad fuel. Wondering where you fuel up and if this is just 93 or if you added e85/booster.
10-15-2020, 01:25 PM | #22 |
Rep 23
Im in Upstate NY, like 2-3 hours from the city, also this is just 93. It may look like I have e85, possibly due to my downpipe possibly being loose
