10-11-2020, 11:42 AM | #1 |
Rep 145
Drives: 2021 X3 xDrive30e x-Line
Driving Assistant vs. Driving Assistant Plus
Hi there. In my country BMW sells X3's with two options for Driving Assistant: DA and DA Plus (not Professional).
According to BMW's marketing materials both options have: - rear collision prevention - crossing traffic warning rear - lane departure warning - lane changing warning - approach control waring And the "Plus" adds the following: - steering and lane keep assistant with active side collision protection - crossroads waring - evasion aid - crossing traffic warning front It is not clear for me whether or not the basic DP option has the "ACC + stop & go” as the marketing materials are not clear. It is mentioned in both versions that “BMW DA allows smart driving in situation such as traffic jam, slow traffic or long trips”, but it is not crystal clear on the ACC thing. People from different concessionaires tell you controversial information. The Plus option definitely has it as it doesn’t make sense having steering assistant and not ACC. Can anyone bring some light into this? Thanks, |
10-11-2020, 12:16 PM | #2 |
Rep 113
Many companies have misleading or confused features in their literature. Mostly because they don't know what they are planning to deliver or have different features across their model lines. Land Rover is another example.
To answer your question, I have DA and DO NOT have ACC or lane keeping assistance. Only lane keeping alerts and the other things you listed under DA. |
10-11-2020, 07:05 PM | #3 |
Rep 145
Thanks. That's helpful. You are right. This is very confusing and poorly managed by car makers. Nowadays, tech in cars is a hot issue and sometimes decisive when buying luxury expensive cars. It should be more clear to customers what it is being offered.
10-11-2020, 09:25 PM | #4 |
Rep 1,108
To me, BMW ranks amongst the worse in giving you any clarity in what you are getting with various options. Like you said, you spend so much money - there is no reason to not be clear as to what you are getting for the options you spend on. This has let me to configure past X3s based on information that wasn't complete. If they do not list a "Professional" option, nor does it list it - am I to assume that ACC is not available in your region?
Alias1431799.50 |
10-12-2020, 07:08 AM | #5 | ||
Rep 145
Just for you guys to understand where this confusion is coming from: I was checking the G20 (320i M Sport) specs (local production, not imported) and BMW sells it here with the “basic DA” option included that has the "ACC + Stop & Go” and the same catchy phrase "BMW DA allows smart driving in situation such as traffic jam, slow traffic or long trips" Specs for G20 320 M Sport local production - rear collision prevention - crossing traffic warning rear - lane departure warning - lane changing warning - approach control waring - active cruise control None of the “DA Plus” options listed in my original post are present in the G20 specs for the 320i M Sport model. Quote:
Thanks! |
10-12-2020, 07:56 AM | #6 | |
Rep 79
For example I have DA "Pro" in my 2021 X3 (I think in 2020 it was only available as "plus"). However mine doesn't have the eye-tracking camera that allows it to do the extended traffic jam assist that the X5 gets with its DA Pro package. Frustrating... |
10-12-2020, 08:30 AM | #7 |
Rep 2,046
Drives: X3 G01 30i xDrive
I don't know how it is now, but ACC used to be also available as a stand-alone option. They might have integrated it to DA of Pro/Plus.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
10-12-2020, 10:40 AM | #8 |
Rep 590
I'm looking at this info also. Standard equipment is:
Active Driving Assistant (5AS) Active Blind Spot Detection (ZN1) Frontal Collision Warning w/ City Collision Mitigation (ZN3) Lane Departure Warning (ZN4) If you get the Diving Assistance Pro $1700 (ZDY) you get: ACC S&G + Active Driving Assistant (5AT) This deletes standard 5AS So for $1700, is the only thing you get is the ACC S&G since the Active Driving Assistant (5AT) is standard equipment? My guess is that when you order this package, you are getting the lane keeping assistant and not just a warning, as well as a traffic jam assistant (whatever that is) and a few other things not as standard equipment. Can anyone verify this? |
10-12-2020, 12:52 PM | #9 | |
Rep 79
I speced my 2021 with DA Pro. It does indeed have the lane keep assist, which is the active lane hold function, as well as adaptive cruise and traffic jam. I have only had the car for 2 days and only had the chance to try the traffic jam assist once. But it works well. You have to keep your hand on the wheel (or just a finger touching it really), but it will take care of dealing with stop and go traffic just fine (at least in the limited amount I have had to test it, which was for a total of 2 minutes or so) |
10-12-2020, 06:00 PM | #10 | |
Rep 590
Does the traffic jam assist work in conjunction with the ACC S&G? So if your in a traffic situation, the X3 will follow, stop and start and stay in the lane with only placing your finger or hand on the wheel? You can take your feet off the brake and gas? |
10-12-2020, 07:08 PM | #11 | |
Rep 79
The lane keep isn't perfect but it's pretty good (it was actually better in my Honda Ridgeline that I just traded in). But otherwise I would trust it to keep the lane without much bouncing around. You just need to have a finger on the wheel and it can sense that. In reality I find I just put my hand on the bottom of the wheel and leave it there, and the car basically drives itself. The traffic jam assist is a part of the adaptive cruise. When I got into a bit of traffic I was at a standstill. I turned on the adaptive cruise and set it to 60mph even though I was at a dead stop. I set the lane keep on, then let go of the brake. I didn't go anywhere. When traffic moved in front of me, the car started moving and followed the car in front. It stopped and started all on its own and I did nothing other than touch the steering wheel. I can certainly see these assistance features helping with long drives. You can let your attention waver even like 15% and you will be much more relaxed. And by 15% I mean you can take a look around, check the scenery, but still watch what's happening on the road. You can grab your drink with both hands and open a soda bottle cap, and trust that the car will stay in the lane for a few seconds. My Ridgeline was great for long trips like that (it's lane keep was really good). But it didn't have the stop and go that will be really excellent when traffic jams are a thing again |
10-12-2020, 08:53 PM | #12 |
Rep 145
I think I got it. I found the BMW USA press release for the X3 (https://www.bmwusanews.com/newsrelea...d=3514&mid=115) and a 2021 model update press release (https://www.bmwusanews.com/newsrelea...=&searchresult) that were very helpful.
From the X3 30e launch press release (dated Nov 2019) for 2020 model: Driving Assistance Package - Active Blind Spot Detection - Lane departure Warning - Rear cross-traffic alert - Speed Limit information Driving Assistance Plus Package - Traffic Jam Assistant - Active Cruise Control with Stop & Go - Active Lane Keeping Assistant with side collision avoidance - Evasion Aid - Front cross-traffic alert In theory, things were clear, but then I found another stuff in the 2021 model update press release (dated Aug 2020): The 2021 X3 began production in 8/2020. Driving Assistance Package This package has been removed. Active Driving Assistant is now standard. So after August 2020 they started production for the 2021 model and it now has “Active Driving Assistant” and not anymore “Driving Assistant” or “Driving Assistant Plus”. From the bmwusa.com Build Your Own site for 2021 model: ACC Stop & Go + Active Driving Assistant Be secure in the knowledge that the latest in safety technology is at your side, sensing all types of potential hazards. In addition to Active Driving Assistant contents, Active Cruise Control with Stop & Go maintains your selected speed. This radar-based system keeps your preselected distance from the vehicle ahead with autonomous braking, if needed. Also included are Active Lane Keeping Assist with Side Collision Avoidance, Front Cross-Traffic Alert, Traffic Jam Assist and Evasion Aid. In conclusion the ACC Stop & Go is added with the new “Active Driving Assistant” Package. Couldn’t be more confusing. Wondering how this would get down here in local market... |
10-13-2020, 02:46 PM | #13 | |
Rep 590
As far as the lane keeping assist, if your on a highway with all the semi-autonomous features set and you come up to a car or truck in your lane as the X3 is driving itself, will it pass the vehicle and then pull back in the lane by itself? I thought I saw this happen on a BMW promo and can't remember what you had to do to make that happen. |
10-13-2020, 02:57 PM | #14 | |
Rep 590
10-13-2020, 03:08 PM | #15 | |
Rep 79
The BMW defaults to 4 car lengths, and you can change it down to 1. But it alwasy defaults to 4 which I find annoying (I would rather it default to 1). I don't know what it would do if a car it is following jams its brakes but I assume it will also. The car does not automatically change lanes to avoid a car going slower ahead of it. It simply slows down to whatever speed that car is going. You will need to change lanes manually before it decides it needs to slow down. To get that that feature you need the X5 or M340i's version of the DA Pro which we don't get (needs the eye tracking system I guess). I bet we could code the fancy instrument cluster display though since we have all the necessary cameras and radars. However doing so is beyond the knowledge I have as a 4-day old BMW owner Last edited by g_lev; 10-13-2020 at 03:11 PM.. Reason: Adding info |
robe03373.00 |
10-13-2020, 03:17 PM | #16 | |
Rep 590
10-13-2020, 07:58 PM | #17 | |
Rep 1,108
The problem I have with the traffic jam assist is when the car in front of your stops, and your car stops - I always had to tap on the gas to get the car moving again. I don't know if there is a time limit as to when it would start on it's own again but I always had to tap the gas. I thought it would start to move on it's own. I read somewhere that I could also just press the RES button but that didn't work for me either. I might be using it wrong. lol This is all from a 2018 model, though - maybe it's all different with the current models. The lane changing feature you describe was never offered in the US I don't think? (Or was it?) That is when you flip the lane change signal and your car would change lanes for you on it's own. But I don't recall it ever being smart enough to then go back to the lane by itself after you passed someone? |
10-13-2020, 10:17 PM | #18 | |
Rep 184
10-13-2020, 11:19 PM | #19 |
Rep 746
Usually it's a timeframe of only 2-3 seconds where the car will continue to drive automatically after a stop. Instead of a tap on the gas, you can also just push the resume button on the steering wheel.
10-14-2020, 09:52 AM | #20 |
Rep 590
I wonder if they'll put the auto lane change in to the MY 2022. Can't wait for that though. Thanks for your explanations. On long drives it seems like its a help though and worth it.
10-14-2020, 10:26 AM | #21 |
Rep 339
My other car is a Tesla Model 3 with "Enhanced" Autopilot, and for what its worth I hate the auto lane-change feature. Its terrifying and I have it turned off. The rear radar on any consumer car can't see that far back. Imagine for a moment you're on the highway going 70mph and the car starts to turn into the leftmost lane to avoid a slower car. Now imagine in that left-most lane there is somebody who is _really_ speeding, maybe they're going 90 or 95mph and coming up quickly on you as you automatically change lanes. Without manual intervention that car would smash into the back of your car.
I've been in scenarios where this has happened and I have to take over immediately to avoid getting rear-ended. This is why this is disabled on my car. The tech isn't there -- at least on the Tesla. What I _do_ have enabled, is the Tesla will ask me whether or not it is allowed to change lanes, and you depress the stalk in the direction of change to acknowledge and accept its suggestion. This tech is fine and requires the driver to opt in. |
10-14-2020, 10:34 AM | #22 | |
Rep 79
Most of the time "directing the action" to me means "hey car, please just stay in this lane unless I say otherwise". So the current level of tech is about just right for me. |
