10-15-2020, 11:27 AM | #1 |
Rep 674
Spare Jack Kit
Using one of my original tires/wheels for spare, and need a compact trunk jack. Looked on ECS, Ebay, Amazon and Bimmerworld and not finding model match.
Any one have a suggestion for F22 ? Like to have matching lug wrench with Searched here but a couple links no longer work ALSO - is it possible to use OEM wheel lock on 75mm studs ? Or too long ? Cheers and thx Last edited by 4Hockey4; 10-15-2020 at 11:37 AM.. |
10-16-2020, 03:05 PM | #2 |
Rep 560
I got these 2 items:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The jack works fine. I haven't used the lug wrench, because at home I use my torque wrench. So I can't provide feedback on that.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
10-16-2020, 03:42 PM | #3 |
Rep 8,942
The BMW branded lug wrench is actually very nice and set to the proper torque. I don't have the part # but if you search you should be able to find it. There are quite a few threads on this topic. You also may want to get a longer breaker bar to keep in the trunk for stubborn bolts.
BTW I've also got an E46 mine is a ZHP but think they all came with the same spare kit. That scissor jack is horrible and dangerous don't use it.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
elliswyatt69.50 PeterWT264.50 |
10-16-2020, 04:18 PM | #4 |
Rep 3,507
The torque wrench part number is 71126769683. Handy little tool, that one is.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
10-17-2020, 09:40 AM | #5 |
Rep 110
Wow, I had no idea this existed. Great find, thanks.
10-17-2020, 10:37 AM | #6 | |
Rep 560
I've used that jack in my daughter's ZHP. It's bizarre. I can't believe BMW made it and equipped the E46 with it from the factory.
10-17-2020, 01:22 PM | #7 |
Rep 674
10-18-2020, 12:38 PM | #8 |
Rep 2,882
Not sure if it is truly OEM for the 2 series, but they do make a scissor jack with a top pad that fits into the frame holes. DK if you can buy separately, but it is part of the spare kit they sell, nested inside the space saver. This link is one example, from the nearby thread titled 'space saver' : https://modernspare.com/product/2013...-complete-kit/
Beefy84.00 |
10-18-2020, 01:34 PM | #9 | |
Rep 560
Maynard3861.50 |
10-18-2020, 02:26 PM | #10 | |
Rep 674
https://modernspare.com/product/2013...sory-only-kit/ |
Maynard3861.50 |
10-27-2020, 07:46 PM | #11 |
Rep 449
I'm using a jack that was originally in an E39 5 series.
P# 1 096 040. 1 aka 71121096040 ECS sells these new: https://www.ecstuning.com/b-genuine-...k/71121096040/ You can buy them other places, like Turner, for similar prices. I bought mine used for $50 off eBay. As for the comments on these little jacks being sketchy, well, they ALL suck. The BMW ones at least have a block that fits into the jack point, stabilizing the top point. But these tiny spare jacks are all horrible no matter what brand of car. I would never use one if I had any other jack available. I still need to source the cute little folding wheel chock that BMW had in some kits: https://www.ecstuning.com/b-genuine-...k/71121507292/ That BMW torque wrench is cool. But I would rather have a longer breaker bar and socket. A bit more flexible. And don't forget a decent tire plug kit and a compressor with some optional slime sealant. |
03-13-2021, 01:43 PM | #12 | |
Rep 674
03-15-2021, 11:41 AM | #13 |
msej449
515
Rep 718
Drives: M235i Convertible +LSD 2016
The BMW Preset Torque Wrench 140Nm #71126769683 has a thread all of its own here including a photo plus some user feedback and advice.
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric) |
shadowfax1289.00 |
04-07-2021, 11:28 PM | #14 |
Rep 452
Skip the torque wrench..honestly you’re overpaying and over thinking it.
Get either the $11 or $13 harbor fright breaker bar and literally whatever cheapest deep socket 17mm you can find. This is a spare tire swap emergency kit. Whatever you do here is not a permanent install. If you’re throwing a spare tire on, it’s temporary. Tighten it down and your objective is to get to the next place that can swap/repair the tire and they will more than likely install it to correct torque specs after. Also...the angle of that Bmw torque wrench is awful.. |
04-08-2021, 09:40 AM | #15 | |
Rep 3,507
04-08-2021, 07:24 PM | #16 | |
Rep 452
I have a full sized spare for that same exact reason. Always have, and have never had an issue hand torqueing a tire with a breaker bar or with a traditional tire iron. It will get you far enough on that and Ive done it that way for YEARS without ever having an issue. Odds are the non-matched tires will do damage long before any "overtorquing" would in that situation. I also dont plan on cruising a thousand miles on my spare. |
spidy512502.00 |
04-08-2021, 07:28 PM | #17 |
Rep 3,507
I hear you. Torque wrenches are not intended to be used for removing wheel bolts or stud nuts. Do people really do that?
04-12-2021, 02:53 PM | #18 |
Rep 452
Im willing to bet thats exactly how the torque wrench will be used in any customer's situation, as nobody explicitly warns you not to do so and our cars dont come with a tire iron.
Ideally you'd carry the torque wrench + a breaker bar and 17mm socket but thats two tools now...and still seems like overkill for the fact that its a temporary fix any way you look at it. |
