F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Regular or extreme lows for Xdrive
Studio RSR
      10-16-2020, 01:13 AM   #1
Mun Mun
Mun Mun's Avatar
Drives: 2015 BMW 435I Xdrive
Hey everyone, I have a 435i coupe xdrive. I really wanna kill the wheel gap on my car. Im thinking of getting bc racing coilovers. BR series. I'm looking for a tire-to-fender/stance look. I was wondering will the coilovers give me the look I'm going for because I know the RWD can go low but haven't seen nothing for the Xdrive, or should I go for the extreme lows. I do not have EDC
      10-16-2020, 07:28 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The last thing I'd do in Toronto is to lower the car, unless you put it up for the winter. Lowered cars, snow and potholes are a bad combination.
      10-16-2020, 07:45 AM   #3
Omar.c
Omar.c's Avatar
Drives: 2015 F32 428i xdrive
I have coilovers on my xdrive, I played around with a few lowering options.
First 2 pics show my current ride height and I love it. Looks great imo, has a composed ride and comfortable over bumps. I also didn't worry about scraping.
Second pic was when I had the car slammed all the way down just to see what it would look like. This lasted only a few hours. The ride felt noticeably worse due to less spring travel and I personally don't like the slammed look. It's also stressing the axles when it's that low so I didn't wanna cause any damage.
Hope this helps!
      10-16-2020, 01:17 PM   #4
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
I did this on my 2013 335i xdrive
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      10-16-2020, 07:53 PM   #5
blumagic
blumagic's Avatar
313
Drives: 2014 328i xdrive , 2013 SHO
Just get the standard BR, I’m pretty low on Emmanuel design springs and the axle angle makes me nervous to turn xdrive back on
      10-16-2020, 10:56 PM   #6
FastF30
FastF30's Avatar
521
Drives: 2015 335i xdrive Msport Mbrake
Hope this helps!
Your current height looks nice... how much of a drop is it... I was planning 30-35mm
      10-17-2020, 04:56 PM   #7
Omar.c
Omar.c's Avatar
Hope this helps!
Thanks! It was originally about 3 finger gaps stock xdrive. I'm now sitting at one finger gap all around. Sorry I don't know the exact mm drop.
      10-17-2020, 05:16 PM   #8
FastF30
FastF30's Avatar
521
Lol... well after measuring my fingers ... it equals about what I was planning.. 30-35mm 1-3/8"-1-1/2" ...
      10-23-2020, 07:52 PM   #9
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
It's very important to note that as the suspension is lowered the negative camber increases. The chances breaking the front axle (half shaft) on lowered xDrive vehicles increase significantly if negative camber is greater than stock.
Four wheel alignment is highly recommended after lowering xDrive vehicles.
      12-04-2020, 08:49 PM   #10
FastF30
FastF30's Avatar
521
Mun Mun zole2112 blumagic smak168 anielsen71 cfm56d7b
Hey guys ... just want to hear if anybody has issues with lowered Xdrives... I just got mine dropped 1-1/2" and just read someone has issues only after 3500miles dropped only 1-1/4" and yes he had an alignment.... your responses would be greatly appreciated...
My Fender height is 25-3/4"Front & 25-7/8"Rear
      12-05-2020, 12:23 AM   #11
smak168
smak168's Avatar
Drives: 2019 440i xdrive GC
Hey FastF30.
I"ve had no issues...however, I only dropped by 1.0" fronts and 0.8" Rear. I also changed to F80 M3 bump stops which were about 1/2" shorter than my stock F36 bump stops. But was enough for me to get rid of that xdrive gap.
FastF30521.00
cfm56d7b5947.00
      12-05-2020, 12:56 AM   #12
smak168
smak168's Avatar
sorry for the huge pics...you may need to lead back a bit...not sure how to make them smaller...
      12-05-2020, 09:31 AM   #13
cfm56d7b
smak168, thanks for sharing the pictures. Dropping xDrive suspension more than 0.8" - 1.0" wouldn't be prudent. Your drop is just right.
      12-05-2020, 10:29 AM   #14
lonecitizenfour
Drives: 2014 428i XDrive
Hey, just want to say. Be careful when dropping XDrives. I just broke my front axle and my ride height wasn't even that low (Bilstein B14s). But I do have wheel spacers and thicker wheels (8.5 front 9.5 rear)
      12-05-2020, 11:01 AM   #15
Logicoeur
Logicoeur's Avatar
994
Drives: F30 335i xDrive
"Wasn't even that low" is wildly subjective. Hard numbers or we can assume you were tucking tire.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
      12-05-2020, 12:04 PM   #16
FastF30
FastF30's Avatar
521
I'm just trying to figure this all out... what where your tire sizes exactly?... which knuckle of the axle failed... don't think spacers could have that effect except for bearing failure in the hub.. please let me know all data... others have said and most springs are set-up for 7/8" drop... I'm on coilovers so no biggy to change height..
      12-05-2020, 12:19 PM   #17
FrankDK
FrankDK's Avatar
Denmark
173
Drives: f36 435i
Here is mine, lowered on H&R springs with winterwheels on
smak16899.00
BMW BRAD214.00
      12-05-2020, 12:40 PM   #18
FastF30
FastF30's Avatar
521
H&R springs say they are 1-5/8" drop or 40mm drop (I used this as my base when lowering)... can you please measure fender to ground ... and how long have you been dropped... also your car looks real nice...
      12-05-2020, 06:33 PM   #19
FastF30
FastF30's Avatar
521
I've been reading a ton of posts and I'm starting to lean towards there is another issue going on... have you been in any accidents or major potholes... Possible axle support bearing bracket or similar... at that drop you should of had no issues... does make me nervous.... Kies is dropped to 25-1/4" fender to ground on his 335i xdrive which is a 2"+ drop.... alexng72 fender is 25" and reported so far no issues... I'm gonna keep researching..
So let me know root cause and keep us updated.... thanks in advance...
      12-05-2020, 07:09 PM   #20
lonecitizenfour
No accidents or pot holes. The cars has 34k miles haha
I'm in some shit situation right now haha... My only wheels are my Niche ones because I've sold my 17" Stock wheels (I guess it won't fit anyway, because I upgraded to 435i XDrive brakes), so I ordered BBS RS 18"x8" square setup with new tires ($2000 with TPMS), B6 Bilsteins Front and Rear ($650), Stock Springs + Stock Strut Hardware ($800 )... $1250 per axle (I hope it's just one...) and whatever the f*** the labor will be.
I mean do whatever you want with your car, I'm just letting you know what I've experienced and going through now.
It's whatever the highest setting Bilstein recommended for B14s were.
      12-05-2020, 07:30 PM   #21
FastF30
FastF30's Avatar
521
Thanks and Fudgeeee about the $$$$
      12-05-2020, 07:32 PM   #22
FastF30
FastF30's Avatar
521
P.s. check carparts for a used axle... another guy was getting axles for less than a couple hundred on there...
f30post
