**NEW** - PAGID Brake pads now available for 335i/d
10-08-2008, 10:22 PM | #1 |
Rep 5,493
Just to let people know -
Pagid have finally released their upgraded brake pads in both front and rear fitments for the 335i and 335d. The pad pattern numbers are as follows: 335i/d FRONT - Pagid # 8053 335i/d REAR - Pagid # 8051 The pads will be available in the following flavours - Pagid 4-2-1 Black (fast road pad, standard OEM pad on Aston Martin, Ferrari, Lamborghini etc) Pagid 4-2 Blue (fast road pad, higher friction co-efficient than the 4-2-1 Black pad, greater fade resistance, excellent cold friction, possibility of very slight pad squeal when cold) Pagid RS19 Yellow (endurance track pad, low wear characteristics, suitable for Nurburgring and other track days, not ideal for general road use due to excessive pad squeal and reduced cold friction) Pagid RS29 Yellow (development of the RS19, with higher friction levels and greater fade resistance) Pads for the 320-325 models, and the 330 models, will be following in due course. Pads for the 135i (and consequently the BMW Performance Brake Kit) will be available within the next three to four weeks.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
10-09-2008, 06:52 AM | #2 |
Rep 3,465
Ive got some pagid rs19 yellows and i can concour that they squueeelllllll like a whore.
But as they are only for track days the stopping power is amazing.
C350 cdi sport estate facelift 457lbft
130i M SportMercedes C350 CDI Sport Estate AutoMini Cooper Auto.Mercedes E250 CGI,Lexus IS-F,R36, RS4 Saloon,ML 420 CDI SPORT,M6, 335d, C55, C32, M3, M5, S3, ALL SOLD but fondly remembered |
10-09-2008, 07:29 AM | #3 | |
Rep 333
Drives: E89 Z4 35i
Garage List 2003 Radical SR3 Su ... [0.00]
2005 E53 X5 3.0D [0.00] 2007 E92 335D M Spo ... [0.00] 2004 E85 Z4 3.0i SE [8.00] |
i fancy some, but will remove them after each track day and put the OEM pad back in. its not too much of a faf, but probably worth the avoidence brown trouser moment first thing in the morning of a drive to work! Dario
35i - DCT - Most of the toys - Smart top roof module - GLF.
www.onboardvision.co.uk www.gtvr.co.uk www.vehicle-launch-incar-video.co.uk |
10-09-2008, 08:11 AM | #4 | |
Rep 5,493
Speedreligion.net is likely to be cheaper than going through CBP (below), as Ant has a wholesale purchasing deal, and he sponsors our forum Or if you need more info on Pagid products, contact Competition Brake Products directly (Pagid UK distributors), at www.racepads.co.uk or 01748 831200.
10-09-2008, 08:14 AM | #5 | ||
Rep 3,465
I had the Pagids put on with some braided hoses and some race brake fluid and the braking performance was mega. The only downside was the noise. Ant removed them and replaced them with the oems. For each trackday ( im going to croft and oulton) im having them in.
10-09-2008, 08:22 AM | #6 | |
Rep 5,493
Steve, you should consider upgrading the OEM pads (which even on your M6 are the utter rubbish Jurid 310 / Textar 4165 pads) to the Pagid 4-2-1 Black road pads. They give you a HUGE increase in performance, and yet don't squeal... They are a little bit more dusty though, but you can't have everything!!
10-09-2008, 08:23 AM | #7 | |
Right Responsible
58
Rep 1,646
Can you recommend any of the pagid pads you listed as a direct replacement for the OEM pads?
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
10-09-2008, 08:24 AM | #8 |
Rep 5,493
As a direct replacement for road use, but offering a massive upgrade in performance, get the Pagid 4-2-1 Black.
10-09-2008, 08:48 AM | #9 |
Right Responsible
58
Rep 1,646
Thanks
10-09-2008, 02:18 PM | #11 | |
Rep 3,465
The performance of tbhe yellow is mega but the noise is embarrasing in the high st when the yellows run out next year then ill just fit the Pagid 4-2-1 Black road pads and save the hassle of cahnging before each trackday.
10-09-2008, 02:20 PM | #12 | |
Rep 5,493
10-10-2008, 02:14 PM | #14 |
Rep 9,915
Drives: VW T5
10-10-2008, 04:21 PM | #15 | |
Rep 5,493
He only has the RS19 Yellow track pads listed, for the 335i/d. The front pads for the rest of the E9x range have not been made yet, although they will become available within the next three to four weeks.
10-10-2008, 04:22 PM | #16 |
Rep 5,493
You have to release the front caliper by undoing the hex bolts, swing the caliper off the disc, then replace the pads, and put the whole thing back together again. Worth bleeding the brake lines as well at the same time. Or, take your car to a garage and pay them one hour's labour to do it for you
10-11-2008, 07:26 AM | #17 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
Tony any reccomendations for the DXB?
997.2 GT3
10-11-2008, 01:28 PM | #18 |
Rep 5,493
As I've already written above mate. You should get Pagid 4-2-1 pads on the front next time you need new pads
03-18-2011, 06:23 AM | #20 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
Will the pads fit on the OEM brake discs? and do I need to change the brake fluid type aswell?...or will it work with standard BMW brake fluid?
What is roughly the price difference when compared to the BMW ones? |
03-18-2011, 07:32 AM | #22 |
Rep 914
Hi,
I have been researching a fair bit, and it seems we maybe in the same boat. You can replace oem pads with a number of different ones. I have decided to use the EBC yellowsftuff pads My understanding is that to replace the brake fluid is recommended, but standard will wrk, but perhaps not extract the mx performance from the pads. but the standard lines are generally hardy enough for occasional track use and fast road check out my thread on the issue, some good advice from other members on there |
