93 Octane Upgraded Turbos Realistic Figures?
10-31-2020, 03:44 AM | #1 |
Rep 100
Hey everyone, hope you are all well.
I am going to be upgrading the turbos on my 35is in the near future. I am looking to put in a pair of upgraded twins. I am from the UK so no E85 unfortunately, the best fuel I can get hold of is 93 octane (99 ron). I am wanting to make circa 600bhp at the crank, is this possible with 93 octane, or will I need to consider methanol injection? My car is RHD fyi. Thanks all for input. |
10-31-2020, 05:22 AM | #2 | |
Rep 1,815
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
10-31-2020, 06:10 AM | #3 | |
Rep 3,219
You will probably need turbos like RB 2 plus with Inlets and outlets. Probably best if you speak to a N54 tuning specialist. Or email RB Turbos and ask Rob. |
10-31-2020, 08:22 AM | #4 |
Rep 317
475 - 500 whp is about the most hybrids do on 93 octane. The latest RB Game Finishers though have made 581whp on 93 octane. I'm not sure I would drive it on that all day, every day though, as 93 octane can be poor at times. Plus, ethanol gives a good cooling ability which greatly helps since we have cast pistons.
So - TLDR - Peak - 580whp Realistic - 475whp |
10-31-2020, 01:06 PM | #5 | |
Rep 3,219
10-31-2020, 03:11 PM | #6 |
Rep 946
Lets say 15% drivetrain loss 545bhp 670bhp
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
10-31-2020, 03:18 PM | #7 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
To answer you would need to add meth + 93 to get up to 600hp OP w/o any ethanol
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-31-2020, 04:58 PM | #8 |
Rep 3,219
So about 510whp with that drive loss, for 600bhp at the crank?
That should be possible with 93oct only, depending on the turbos right? I mean i understand the benefits of Ethanol/Methanol but it's not easily accessible and pain in the butt to get hold of in UK What would you say is a safe Whp/crank hp to run at for daily? Also the ratings on RB turbos website are they max whp the turbos can safely push with Ethanol or 93oct? Last edited by Saif2018; 10-31-2020 at 05:03 PM.. |
11-06-2020, 03:49 AM | #9 |
Rep 466
The answer is No. your very octane limited from making big power
Generally with low octane fuel like stand pump 91/93 octane the limit of this engine is about 500whp. This is with all the bolts one and with much bigger than stock turbos. If you want more power then you must run much more higher boost Numbers and more aggressive timing number that normal 91/93 octane Simply cannot support. But with high octane fuel like e85 or race gas or meth injection the potential in limitless like well over 1000whp. Anytime a turbo is rated for say 600whp or 700whp, these numbers can only be achieved with high octane fuel. You can never max out the flow capabilities and the potential of a turbo on low octane 91/93 octane fuel.
2007 e90 335i
pure stage 2 DD turbos, rb inlets Last edited by Riceball777; 11-06-2020 at 03:55 AM.. |
11-10-2020, 06:58 AM | #10 | |
Rep 3,219
11-12-2020, 01:05 PM | #11 |
Rep 823
Talking about a crank number is just inviting all sorts of unknowns and bad guesses since the drivetrain loss % isn't necessarily linear, nor is it precisely known, nor are most people great at math. 500whp could easily be between 550hp and 667hp at the crank, depending on who's doing the math and what loss % they're using.
In this thread, 475whp was said to be 545hp at the crank, given a 15% drivetrain loss, and this is the kind of wrong math I see most people do. 475 x 1.15 makes sense to most people, but this is not a 15% loss on the crank hp. This is a 15% gain on the whp, and that's not what we want. To find the theoretical crank hp, you must divide the whp by the remaining percentage after loss is subtracted. In other words, crank hp = whp / (100% - loss %). In this case it's 475 / .85, which is 559hp at the crank. Thanks for letting me get this off my chest.
2008 335xi 6MT - 16T China Turbskies - eBay FMIC, DP & CP - VRSF Inlets - SSR DCI's - Walbro 450 LPFP - RFP e85 Tune
11-13-2020, 07:02 AM | #12 | |
Rep 3,219
Do we have actual loss figures for both? I mean obviously it will vary, just like dynos vary, but do we have some sort of ball park figures for both? Last edited by Saif2018; 11-13-2020 at 12:30 PM.. |
11-13-2020, 10:12 AM | #13 |
Rep 823
Sure, the drivetrain loss is higher on xDrive than RWD, but I don't think anyone has actual loss figures for either of them. And at the end of the day, it's a rather vain pursuit since whp is what determines performance anyway.
From what I've gathered, 275whp is a pretty average stock 335i number while 260whp is standard for a stock 335xi. 275whp with 15% loss gives you 324hp at the crank while 260whp with 20% loss gives you 325hp at the crank. And since it's common knowledge that the N54 is underrated, 325hp is likely very close to the actual crank power. So I'd be inclined to go with 15% loss for a stock 335i and 20% for a stock 335xi, but who knows what happens to those figures as power is increased? I don't think you can expect to see the same 15% and 20% losses with a 600hp engine. The drivetrain will certainly absorb more hp with a 600hp setup, but I would bet it would be at a much lower percentage, perhaps 10% and 15%. Does that make sense? But to get back to my main point, anytime you're taking whp and attempting to convert it to crank hp, you're guessing and adding in unknown variables in order to arrive at an impractical result (aside from having a higher hp number to brag about). This is why it's best to leave crank hp numbers to the manufacturers (who tend to lie about them anyway).
11-13-2020, 12:33 PM | #14 | |
Rep 3,219
So assuming the OP is targeting 500whp that should be achievable on 93 Oct pump gas (Stage 2 Turbos) right? |
11-13-2020, 07:15 PM | #15 |
Rep 466
500whp is very hard to do on normal 91/93octane. Its possible and on the upper limits of this engine assuming you have 93/94 octane and not 91octrane and you have a big single turbo with all the bolt ons with a good tune. Its definitely much much harder with upgraded twin turbos.
Here is my 335i n54 dyno. I made 504whp and 504tq. This is with all the bolts on and with pure stage 2 turbos running 21psi of boost with 50%e85 fuel and 50%91octane. Because I don’t have port injection my high pressure fuel pump is maxed out. With only 91 octane I would guess I would be somewhere in the low to mid 400whp range. If i had port injection i can easily just run full e85 and max out the turbo and be in the 600whp range.
2007 e90 335i
pure stage 2 DD turbos, rb inlets Last edited by Riceball777; 11-13-2020 at 07:25 PM.. |
11-13-2020, 10:56 PM | #17 | |
Rep 466
We’re talking about making power on low octane 91/93 octane pump fuel with no meth injection or race gas or e85.
2007 e90 335i
pure stage 2 DD turbos, rb inlets |
11-13-2020, 11:08 PM | #18 | |
Rep 3,219
I mean if all your going to get is about 450whp reasonably, better to stick to stock TD03 and use E85, could easily get 400-450whp. Asking because I will be in the same boat as OP in future, I don't have easy access to E85, 93oct is easily available I'm not targeting a specific WHP, but would be a realistic WHP figure for FBO, ( Port injection with Inlets using 93oct only, stage 2 turbos? Last edited by Saif2018; 11-13-2020 at 11:18 PM.. |
11-15-2020, 06:38 PM | #19 |
Rep 317
