GetBMWParts
BMW M2 Forum > BMW M2 CS Model > M2cs winter driving
      11-10-2020, 10:27 PM   #1
H82BL8
H82BL8's Avatar
133
REP
42
Drives: m2 competition now m2CS
M2cs winter driving
Good snowfall today
The m2cs with proper winter tires made winter driving enjoyable not stressful.
The rear drive differential doing its magic was great.
Front splitter or snow plow?
Hedoniste4052.00
cncmastr1629.50
Bimmed Out1908.50
Supadice1039.00
Tornado1M1288.50
6speed_M210029.00
pizza2401216.50
      11-11-2020, 02:20 AM   #2
Pol
Pol's Avatar
Belgium
1,131
REP
1,407
Drives: M2 CS BMS DCT August 2020
Originally Posted by H82BL8 View Post
Good snowfall today
Without winterset?
      11-11-2020, 05:14 AM   #3
M-Azing
Antonito
REP
40
Drives: BMW 335i
Good snowfall today
What are you using for winter tires - brand/ size? Thanks
      11-11-2020, 03:26 PM   #4
H82BL8
H82BL8's Avatar
133
REP
42
245/35/19
255/35/19
Micheline Alpine x ice
M-Azing19.50
      11-15-2020, 10:56 AM   #5
Pol
Pol's Avatar
Belgium
1,131
REP
1,407
Do you think it would be a good idea to install M 437's as a winter set?
There is so little space between the front of the caliper and the inside of the rim.
      11-15-2020, 11:41 AM   #6
QM
REP
312
Drives: 2020 M2CS 6MT
If 437s fit the M2C they should fit the M2CS as well. I'm also looking into a 641m 19 inch winter set.
      11-15-2020, 11:58 AM   #7
Pol
Pol's Avatar
Belgium
1,131
REP
1,407
The weight of the 641 is much higher than the 763 and the 437. I had the black 640's (18") on the M2 OG as a winter set.
QM287.00
      11-15-2020, 12:00 PM   #8
kart driver
REP
658
Drives: M & GT
The 437 fit absolutely fine. Same size as 763s.
And the are not heavy as opposed to 788s.
763:
front: 9.4 kg; rear: 9.9 kg
437:
front: 10 kg; rear: 10.7 kg
788:
front: 11.2 kg; rear: 11.9 kg
P.S. I have been running 245+265 michelin pilot alpin 4 for two winters already and they proved to be fantastic. I have 2NH brakes and had no issues with anything stuck between calipers and the rims. And I drove a lot across the entire Europe from Portugal to Ukraine and from North of Germany to the South of Greece.
QM287.00
      11-15-2020, 12:50 PM   #9
Pol
Pol's Avatar
Belgium
1,131
REP
1,407
763:
437:
788:
Thanks for the reassuring reply. This morning I mounted the winter set on 437's and was surprised by the very slight clearence with the front calipers. But I'm reassured now, thank you very much.
      11-15-2020, 01:05 PM   #10
QM
REP
312
763:
437:
788:
Pol, do you mind posting a picture? Curious to see how close the clearance is to the caliper. Thanks.
      11-15-2020, 01:26 PM   #11
kart driver
REP
658
Drives: M & GT
It is exactly the same as 763s
      11-15-2020, 01:29 PM   #12
Pol
Pol's Avatar
Belgium
1,131
REP
1,407
With pleasure
I measure 1cm.
QM287.00
      11-15-2020, 01:29 PM   #13
dgm3
REP
281
Drives: M3 E36/E46 M2C
763:
437:
788:
265 on the rear is really wide to get proper snow traction... guess that despite driving through all Europe you do not go in hilly/ mountains area
      11-15-2020, 01:36 PM   #14
Pol
Pol's Avatar
Belgium
1,131
REP
1,407
I think you misunderstand, we are talking about the clearance between the inside of the front side of the rim with the calliper.
      11-15-2020, 01:46 PM   #15
Pol
Pol's Avatar
Belgium
1,131
REP
1,407
I think 235 front and 255 rear would be better no??
I had these on the OG M2 withe the 640's.
But now I bought this set for an interesting price second hand with continental wintercontact on for the CS. Front 245-35/19 rear 265-35/19.
      11-15-2020, 01:47 PM   #16
kart driver
REP
658
Drives: M & GT
A friend of mine has 437s on his M2C with 2NH brakes and I never saw that he has any issues with that.
      11-15-2020, 01:56 PM   #17
kart driver
REP
658
Drives: M & GT
I drove many times through Alps during winter with my 245/265.
Trust me there is no need to worry. Those will work just fine.
      11-15-2020, 03:22 PM   #18
wolf2871
REP
17
Drives: M2 CS (On Order)
I just installed a set of 641s with 235 Alpin 4s today as recommended by BMW.
Took it for a test drive and the front right had a shallow scrape all the way around the inside of the wheel. I pulled the wheel and could not see any where on the caliper where it could have been scraping. It wasn't any part of the red caliper as there was no red paint transfer.
I re-seated it this evening. Hoping I just didn't have it on the hub flush. We'll see after my drive to work in the morning.
All the other wheels were fine. And the wheel with the issue spun freely when installed.
Any thoughts?
      11-15-2020, 03:33 PM   #19
QM
REP
312
Maybe it was a stone. The other front wheel was fine? Keep us informed please whether it happens again after your next drive.
pizza2401216.50
      11-15-2020, 04:46 PM   #20
CarJunkie
CarJunkie's Avatar
REP
2,819
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
^^This. I must have had a stone between a front caliper and one of my track wheels last spring. I didn't see the circumferential marring on the back of the wheel until I was cleaning them after the track day. I was able to find the small mark on the caliper where the stone had lodged. If you carefully inspect the bottom of the caliper, you may also find yours.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
      11-16-2020, 12:42 PM   #21
wolf2871
REP
17
So no issues today. We'll mark it up to either a rock or it wasn't mounted properly. If anything happens in the future I'll let you all know.
QM287.00
      11-17-2020, 09:52 PM   #22
QM
REP
312
How is the handling with 235s on those 641ms? Are 255s available on 641s?
m2
