11-17-2020, 08:32 PM | #1 |
Rep 1,221
BM3 stopped flashing custom tunes
Picked up my F97 from a 13k mile service today. They swapped out spark plugs already, fixed the 2 recalls (rear camera and something else) and also did some work on the DME they said. Of course everything was reset to factory, so I tried flashing back my stage 2 map once home. No dice! It loads to 5 percent then jumps to clearing codes in the primary modules, then secondary, then fails out. Drivetrain malfunction shows up on the dash too blocking the engine from starting. I began to panic, tried other tunes, same result. Finally flashed to stock tune and everything is working again. I've emailed protuningfreaks about it already. Hopefully they have a fix soon. It's been a while since I've driven stock flash having been enjoying stage 2 93 and E30 tunes for a while now.
11-17-2020, 09:00 PM | #2 | |
Rep 608
r33_RGSport13123.50 |
11-17-2020, 09:16 PM | #3 | |
Rep 4,607
11-17-2020, 09:41 PM | #4 |
Rep 18,795
Man, I hope it is not because BMW locking the DME.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 Coupon Code: "MEMORIAL" MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
11-17-2020, 09:53 PM | #5 |
Rep 4,607
11-17-2020, 10:12 PM | #6 |
Rep 608
11-18-2020, 12:29 AM | #7 |
Rep 18,795
That's true too. Hmm.
11-18-2020, 01:40 AM | #8 | |
Rep 36
When you connect up, on the bootmod3 agent console, what versions does it say your DME files are? Can you screenshot? It should start with BTLD_, SWFL_, CAFD, SWFK_, etc |
11-18-2020, 02:45 AM | #10 | |
Rep 200
11-18-2020, 03:46 AM | #11 | |
Rep 36
11-18-2020, 05:38 AM | #12 |
Rep 1,209
Had similar work done to my car and Mission Performance tune loaded right away, something wrong with BM3?
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
11-18-2020, 06:37 AM | #14 |
Rep 1,221
Mine is a US spec. I also went in with bimmercode and restored all my custom settings. That worked fine. But when I cabled in with BM3 to flash the DME my experience was identical to carmicro's
11-18-2020, 07:35 AM | #15 | |
Rep 36
What version is yours when you connect up to bootmod3? |
11-18-2020, 11:12 AM | #16 |
Rep 200
Had protuning freaks support come back to me saying my software ID both current and reg are fine I have no error codes and suggested I try again making sure my battery or cable are in top top condition. They say if it normally fails between 3% - 83% its usually cable hart issue. The question I need to know is what changed since yesterday when it did not flash till today?. Lucky I could flash back to stock otherwise my car wont start due to drivetrain malfunction. Not tried to reflash yet because Im a bit worried 🤨
11-18-2020, 11:44 AM | #17 | |
Rep 608
11-18-2020, 04:54 PM | #18 |
Rep 1,221
So, preliminary troubleshooting with protuning looks like the software version bmw just dropped in my DME may not be supported by protuning as I can't even get their software to read and display the version I'm running. I've sent them some more info on my car. Hopefully they'll have a solution soon. In the meantime BEWARE of "free" DME updates from BMW!
11-19-2020, 06:27 AM | #22 |
Rep 608
The red flag is already there. Depending on his relationship with his dealer it's a reasonable ask. Not sure if it's even possible to revert, but in say 6 months if bm3 don't work what would you do?
