Preparing for a manual gearbox conversion
11-20-2020, 03:48 AM | #1 |
Rep 137
Hi Team,
A while ago I sourced the parts for a manual gb swap on my wagon. The parts came from a wrecked car with about 135,000km's per the seller. I believe I have everything I need for the conversion, other than a new clutch and flywheel (I have the used items but don't plan on using them). What, if any, maintenance would you do to the gb, diff, or any other part in preparation for the swap? Are there any checks I can perform before installation? I plan to do RMS when everything is apart. Should I replace any seals on the gb? New fluid is a given, once installed. Any other tips or tricks woukd be appreciated. Hoping to have a crack over the Christmas break. Hope you are all well out there. Stay safe folks. Craig |
11-21-2020, 06:34 AM | #2 |
Slowpoke
245
Rep 291
Only thing you can really do at this point in time is throw in new fluid in the box and diff, get a new selector shaft seal and maybe change the clutch master cylinder and the bushings in your manual pedal box. ZF gearbox parts and overhaul kits are pretty hard to source.
My rear main was dry at 140k kms but I had a fresh seal handy. I chose to leave it alone. I would also look into giving all the shifter components an overhaul like new C clips and aftermarket shift arm bushings. I went with UUC delrin front shift arm bushings and a Turner Motorsports rear shift arm bushing that was tack welded to the factory bushing carrier by Vince iirc. These are good upgrades if you don't plan on going for something like a RTD shifter. If you are swapping diffs, get fresh diff bushings while you are in there. FWIW 6AT 335i's that came with the small bolted 3.46 diffs will bolt right on to a 6mt swapped car without any changes. I have a 6mt shaft and large diff/axles laying around right now which I plan on building, but my auto shaft (only about 3mm longer than a 6mt shaft from memory) and rear end bits work fine. Have a look at Vehicular DIY on YouTube - he has a DIY series on a manual swap which is pretty relevant.
build thread - OEM+ WIDEBODY | Factory Individual Audio, Active Steering, Comfort Access & M-Sport optioned
6MT swapped | Xtreme twin disk & SMF | Advan RSII | ST XTA | F82 M4 heated front seats | BMW Individual interior trims | CIC/Combox retrofits | Custom headlights | 1M/M3 mirrors | 335is auxiliary radiator | LCI tails |
11-22-2020, 06:22 AM | #4 | |
Rep 11,905
Given the gearbox will have 135000 km on it, best to do the shaft seals Also check that there is nothing missing before you start the install Nothing worse then getting half way through the install then finding there is a missing sensor or bolt RealOEM is handy website to check that you have all the parts https://www.realoem.com/bmw/enUS/par...BMW-335i&mg=23 |
11-25-2020, 05:27 AM | #5 | |||
Rep 137
I plan on using OEM fluid, and currently going to use the 550i clutch/FW and stay OEM. I'm at 190,000 km's so planning for the worst when I get to the RMS. I replaced the oil pan gasket recently and it appears to be leak free. (that's obviously wrong, as BMW don't offer that feature). If it is bone dry once I get it all apart, I am not sure what I would do... I almost want it to need replacement so I can justify touching it. I hadn't thought of rebuilding shifter or pedals so I will look in to that for sure. I plan to stay OEM again here, standard shifter but M Sport gear knob is the plan. I have, and plan to use, the diff, driveshaft and axles but great to know I can leave it alone if (when?) I run in to problems and realise I need a running car..... Vehicular DIY is a great channel and I've watched the swap videos a few times now. Quote:
I'm sure I don't have *everything* right now. I bought what I deemed "everything" over a year ago I'm sure.... but no doubt bolts, seals, bushes etc need to be purchased. I appreciate the link. Hope everyone is well out in forum-Aus. We've been pretty lucky in WA with what's gone on but I know it's been horrible for others. Merry Xmas and stay safe! |
11-25-2020, 07:57 PM | #7 |
Rep 184
Drives: 2007 E91 323i M-Sport
Black pre-LCI M-Sport Wagon love
11-25-2020, 09:17 PM | #8 |
Slowpoke
245
Rep 291
That's gorgeous. Going to be a unicorn once swapped!
11-28-2020, 05:48 PM | #9 |
Rep 137
Thanks gents. I tend to agree
What really amazes me is how well these cars hold up. I'm going to hit 190,000km the next time I drive the car and the interior is still really nice, leather in good condition etc. I've owned cars to similar km before that didn't fare nearly as well. Keep up the good mod work out there. There is some great inspiration for those up us that like to tinker.... |
