M2 Technical Topics > Suspension | Brakes | Chassis > DIY question: How to remove Rear strut top hat
      11-26-2020, 06:38 PM   #1
ginohhh
ginohhh's Avatar
Drives: 2022 BMW M3 Competition Xdrive
I'm trying to install a set of m performance coilovers I just purchased and I can't seem to find the right socket skinny enough to fit the rear to take the 12 point nut off. Is there a specific tool I need to buy from BMW or any other place? Help is greatly appreciated. Thank you.
      11-26-2020, 08:17 PM   #2
AWC-F87
AWC-F87's Avatar
437
Drives: 2018 BMW M2
The ghetto way I did it was a quick blast with an impact. I wrapped a rope around the shock shaft a few dozen times and a buddy held it. Definitely spun the shaft a little but I wasn't concerned.
      11-26-2020, 08:20 PM   #3
ginohhh
ginohhh's Avatar
I was thinking that too but I can't even get to the 12 point nut lol. What socket did you use ? What brand ?
      11-26-2020, 08:29 PM   #4
AWC-F87
AWC-F87's Avatar
437
Drives: 2018 BMW M2
Honestly don't remember. I just know it was a 12pt. I think I tried a few I had laying around until one fit in. Worst case, go buy a single 12pt the correct size and grind down the outside diameter
      11-26-2020, 08:32 PM   #5
ginohhh
ginohhh's Avatar
I'll give that a try ! Thanks
      11-26-2020, 11:17 PM   #6
mr_lab_rat
mr_lab_rat's Avatar
566
Drives: 2017 M2, 2018 X1
On the front it was 12 point 18mm, this looks the same. So I held the 18 with vise grips and had a 1/4inch extension with 10mm going through it holding the shaft. Makes sense?
      11-26-2020, 11:53 PM   #7
Matt Devo
Recovering RS4 owner
Drives: 2017 M2
2017 BMW M2  [0.00]
this. use a 1/4" 10mm and extension, with the 10mm socket inside the 18mm and the extension going thru the top
      11-27-2020, 01:15 AM   #8
cpxchewy
Monkey
119
Drives: 2020 M2C
Use a 18mm pass through socket to be able to hold the outside spline while using a normal socket inside
      11-27-2020, 05:35 AM   #9
ginohhh
ginohhh's Avatar
I'll give that a try!
      11-27-2020, 05:36 AM   #10
ginohhh
ginohhh's Avatar
Got it
      11-28-2020, 05:03 PM   #11
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
Top Hat Sockets
Turner sells a 5 piece set of sockets just for this. Will be ordering one when I do my suspension.
At a Point above 7,000 RPM.
      11-28-2020, 08:55 PM   #12
oln08
Drives: '19 M2
I installed my Mperf suspension and this worked perfect: https://www.amazon.com/gp/aw/d/B07RD...b_b_asin_image
They are thin enough to go through and it also has the 22mm pass through that you'll need to torque the new nut that will come with the new coilovers.
I bought a flare nut crowfoot to attach to this so i could also use with the torque wrench.
edit.
just realized it's sold out on amazon. maybe find something similar.
      11-28-2020, 09:24 PM   #13
Caduceus
Australia
342
Drives: 2008 135 (sold), 2017 M2
If you already have the car apart and need a McGyver solution because you can’t get the right tool, buy a cheap set of plumbers tap wrenches / tube spanners.
Find the one that almost fits and tap it down over the nut. They are very soft and will deform to fit the nut. Plus they aren’t on that tight anyway.
Photo shows one I used for this purpose.
2.jpg[/img]
      11-30-2020, 01:26 AM   #14
cpxchewy
Monkey
119
Drives: 2020 M2C
The turner 5 piece (should be the same as ECS and Schwaben brand) doesn't fit the rear shock top hat btw. It's annoying...
      11-30-2020, 07:02 AM   #15
M Fifty
Drives: M2 & 330CI
I used the same feedthrough socket as I did for the front.
m2
