take a look at my log. MHD Stage 2+ V9
12-03-2020, 12:35 AM | #1 |
Rep 8
Drives: 2010 Bmw E90 335i
Hello guys, So I just tuned my car to stage 2+ v9 acn91 with mhd. Tried datalogging, and noticed a decent amount of timing corrections, as well as lpfp dips from 4k rpm until I shift. Can someone take a look at my logs. Cylinder 1 has -5 timing correction and -2.7 on the other cylinders. Is this normal or should it be addressed? Thanks!
Mods: DCI, 7in VRSF IC, Catless dp, eldor coils: (23k miles), ngk 1 step colder plugs gapped 0.022, occ, chargepipe. Running costco ACN91. https://datazap.me/u/tommyxu9/log-16...7-8-9-10-11-22
Zoozoo
12-03-2020, 08:12 AM | #2 | |
Rep 3,219
Your timing corrections are probably due to acn91 which is horrible fuel. Running 93oct should reduce timing corrections, if you don't have access to 93oct then you can try running E85 to reduce timing corrections. I would suggest you fix LPFP issue first though. In the meantime run less aggressive map like Stage 2. |
12-03-2020, 12:33 PM | #3 | ||
Rep 8
Zoozoo
12-04-2020, 01:35 PM | #6 | |
Rep 8
Zoozoo
