Is it safe using heat to remove coolant hose?
12-11-2020, 02:47 PM | #1 |
Rep 245
I’m trying to remove my radiator and can’t remove the lower coolant hose. I’ve been trying for about an hour. Maybe haven’t apply enough force, but I’m doing it VERY carefully because its the original one (06 330i). So I’m thinking on two options:
- use some lubricant - use a heat gun Is there any problem using one of those methods? Any response is appreciated. Thanks in advance |
12-11-2020, 02:57 PM | #2 |
Art Collector
2427
Rep 3,450
Yes. Use a heat gun. I’ve done this a few times now and it worked perfectly. Can’t remember the temp I used but needless to say just be reasonable.
I wouldn’t bother with the lube. You just risk introducing contamination into the system, and heat alone should be enough. Good luck!
When I'm dead, just throw me in the trash.
12-11-2020, 03:08 PM | #3 | |
Rep 245
12-12-2020, 06:21 PM | #8 |
Rep 2,476
12-12-2020, 08:22 PM | #9 |
Rep 780
I agree it's not worth saving, they are dirt cheap. Just use a razor cutting lengthwise where it connects to the radiator.
12-12-2020, 11:52 PM | #10 |
Rep 245
I ended up disconnecting the hose from the thermostat’s side, and removing radiator with the hose still plugged in. Once radiator was out and with the help of the heat gun, it was easy to remove the hose. At the end, I saved the hose and radiator and JB welded the leak.
Of course, I will soon replace radiator and also would like to replace all the cooling system hoses as well. |
3PedalJake2613.50 Buug95918139.50 |
12-13-2020, 09:19 AM | #11 | |
Art Collector
2427
Rep 3,450
I totally forgot to mention that removing the rad makes this wayyyy easier. Glad you ended up doing that.
Nando_e90111.00 |
