BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Paint Protection Film - the flip side?
      12-14-2020, 08:56 AM   #1
gurns
gurns's Avatar
Drives: 2021 G82 Dravit Grey
Hopefully soon I will be taking delivery of my new G82. Having specific areas treated with a PPF material is of keen interest. However, my direct experience with PPF is very limited. I am only familiar with those small pieces around the trailing edge of the rocker panels that come factory installed.
Research on other forums has not produced answers to the following questions:
1. Are there any side effects to the clear coat/paint if and when the PPF is removed?
2. Does the PPF yellow over time due to UV radiation?
3. What are some of your recommended practices, lessons learned, etc. regarding all things PFF?
Thanks for any inputs.
      12-14-2020, 09:29 AM   #2
danniexi
danniexi's Avatar
Drives: 2022 F97 X3M Comp LCI
Originally Posted by gurns View Post
Hopefully soon I will be taking delivery of my new G82. Having specific areas treated with a PPF material is of keen interest. However, my direct experience with PPF is very limited. I am only familiar with those small pieces around the trailing edge of the rocker panels that come factory installed. Research on other forums has not produced answers to the following questions: 1. Are there any side effects to the clear coat/paint if and when the PPF is removed? 2. Does the PPF yellow over time due to UV radiation? 3. What are some of your recommended practices, lessons learned, etc. regarding all things PFF? Thanks for any inputs.
1. i have yet to see any side effects. the only damage that can be done on the paint is entirely on the installation/removal process. make sure you go to someone with experience.
2. only after many many many years, and depending on the environment your car is in. PPF may yellow quicker if it’s left sitting in the sun all year round as oppose to sitting in the garage... but we’re talking about YEARS, not a season or two.
3. dont cheap out on the PPF and the installer. do your research, ask others who have had quality PPF installed around your local area. dont cheap out. and dont cheap out.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
2011ninja3470.00
      12-14-2020, 03:55 PM   #3
ferrix924
Drives: 2022 BMW M3C xDrive
What would you consider a reasonable amount to spend covering the important parts of the car? I have no idea if it should be $2k or $8k so just curious
      12-14-2020, 04:26 PM   #4
danniexi
danniexi's Avatar
i spent $2K for the entire front end + tints for all around except front windshield.
i did get a deal imo. after 5 years, its held up very well.
      12-14-2020, 04:48 PM   #5
chicagoguy0822
Drives: 2022 M4 Convertible (G83)
I was poking around at prices for a G83 Xpel Stealth (when the car is released next year). I was quoted about $8K and that includes a ceramic coating. I can't justify it.
      12-14-2020, 04:49 PM   #6
AndroidRobot
AndroidRobot's Avatar
Drives: 2022 Porsche Boxster GTS
  [0.00]
2022 Porsche Boxste ...  [0.00]
full vehicle in clear is usually about $5k
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order)
2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD)
2018 BMW M2 Mineral Grey(SOLD)
2019 BMW X5 50i Carbon Black/Tartufo (SOLD)
      12-14-2020, 05:21 PM   #7
SickGTR
Drives: 1000whpGTR/ F-82 YAS
Both my cars are clear wrapped and ceramic coated. Best thing ever!! So easy to keep clean and always have perfect paint. It's expensive, but totally worth it in my opinion. 5K give or take is about right
      12-14-2020, 05:35 PM   #8
chicagoguy0822
Thanks. Do you know if the Stealth is that more expensive or did I just talk to a pricey detailer?
      12-15-2020, 10:19 AM   #9
unfoundnemo
unfoundnemo's Avatar
1966
Drives: 2022 i4 M50
2025 BMW iX  [0.00]
2022 BMW i4 M50  [0.00]
I got a quote of $5500 for full clear/gloss or $6500 for full stealth. It's a nominal material difference, so it's really just labor. You might be able to get away with not wrapping a couple of edges with a gloss film, but this is not the case with stealth, it should be the same level of effort as a full vinyl color change.
Current: 2022 i4 M50 | 2025 I20 iX
Gone: 2022 G07 X7 | 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC
      12-15-2020, 11:57 AM   #10
chicagoguy0822
Thank you!
      12-15-2020, 01:49 PM   #11
mlust
Drives: M2
Also take in consideration of the color of your car and the brand of film you are using. Certain films will have a higher gloss because there is less orange peel/texture to it, So some films will look better on black paint then others. Most of the cost is labor install as most companies use a plotter to have a precut pattern before placing it on the vehicle. The cost will go up if the film is hand cut and the edges are rolled around the panel, and removing trim and headlights emblems etc...making it harder to tell if it has any film on it.
As for yellowing, none of the films nowadays should be yellowing. That was a common flaw in the early days due to the type of adhesive that was used but none of the big film companies use that type of adhesive anymore.
      12-16-2020, 03:26 PM   #12
2011ninja
2011ninja's Avatar
Jamaica
3470
Drives: 2022 G80 6MT
I can only comment well worth it...
      12-16-2020, 11:59 PM   #13
toastie
toastie's Avatar
Drives: e39 M5
Honest answer is, how long do you plan on keeping the car? If you are planning on holding onto the car for long term then get PPF. If you're the type of person that switches cars every 2-3 years because you want something new, save your money.
PPF by a good reputable shop will run you about $4-5K for a full front end wrap including rockers and pillars. I'm sure some can do it cheaper or some can do the full car for the same amount of money but each market is different.
You want to be sure the shop takes their time and wraps the edges otherwise you'll get premature bubbling/peeling in the corners.
Most PPF manufacturers offer lifetime warranty against peeling/yellowing so that isn't a concern.
