12-25-2020, 10:15 PM | #1 |
Rep 19
MSS HAS kit help
Hi I install MSS has kit on m2c and not happy with the front height . I try contacting mss but no answer wondering if the mechanic can do something else do make the front lower ? Im all the way down on front and rear , the problem is the front still has a finger gap while rear is no gap and tucking perfectly. For most driver prob is perfect but I like my ride slammed
12-27-2020, 05:45 PM | #2 |
M///modifyer
2497
Rep 1,298
I'd go up another 5-10mm in the rear. Not the answer you wanted but should balance out & look nice imo.
www.targaperformance.com
Best Modified BMW - BMW Nationals 2022 |
baggiedamu10.50 |
12-31-2020, 01:27 PM | #4 | |
Rep 19
01-02-2021, 05:18 AM | #5 |
Rep 9,708
MSS are a professional company with car handling at the forefront of their design. So it's unlikely they will have designed a product to screw up the handling by allowing 'slamming'. As others have said, raise rear to match.
To expand on the design of a suspension system (as it seems the slamming fraternity don't realise the limitations). When BMW designed the damper and spring set, they would have allowed for a particular stroke of damper. They would have then fine tuned the damper length to sit in the mid position on that stroke at normal ride height. So for example, if damper stroke is 120mm, they would aim to centre the piston by adjusting rod length at stock height. This would give 60mm of travel in both directions. Perfect. The user then fits 30mm lowering springs, which moves the piston down to only 30mm compression left (now with 90mm extension). But with standard stiffness springs, the car might experience a regular travel of 50mm of suspension compression. You've only got 30mm until the piston bottoms out. The only way to remedy this on stock dampers is to increase the spring stiffness by a massive amount to reduce the regular 50mm of travel to 30mm. That would be close to double the spring weight. MSS are definitely not in that range. A double the spring rate car will be a bone jarring ride. Horrible. |
01-04-2021, 12:23 PM | #6 | |
Rep 19
