12-28-2020, 08:57 AM | #1 |
Rep 281
Brake service indicator issue
At 30k (kms) on my M2C I got a service message saying that the front pads were due in 2k. At that point the indicator did not further go down despite driving the car for an additional 2k.
Although a quick look at the (outside) pad suggest there was still quite some meat I brought the car to the dealership. They reported an issue with the indicator and reset the system so that it showed 16k until front pads service is due. I am now monitoring the evolution of the indicator but to my surprise it seems like dropping by 1k every actual 0.2 k . It is now showing 8k before service. Anyone with similar experience. Is there a specific issue on my car or is this indicator just a useless/misleading feature of modern cars? Guess there is an algorithm behind this system, anyone know what are the key parameters influencing the estimated remaining mileage calculation ? Thanks |
12-28-2020, 09:32 AM | #2 |
Rep 4,554
Drives: 2015 328d xDrive
The car has brake pad wear sensors (one in the front and one in the rear I believe). I'm no expert but I would gather that the service indicator works with the car's mileage in combination with the sensor data. If you're getting a light despite having lots of pad life I would guess that you have a faulty sensor.
NYC Bimmer259.50 |
12-28-2020, 10:41 AM | #3 |
Rep 4,049
Drives: 2020 M2C, 2019 330xi, 2017 Q7
You have a faulty brake pad wear sensor it seems. If they didn't replace it, you should make them. Resetting something faulty won't rid the problem.
