Rear suspension replacement
12-30-2020, 09:26 PM | #1 |
Rep 252
2011 e92 n55 133,000 miles
I'm replacing the shock absorbers. Should I replace all 3 control arms or just the 2 in this kit from fcp? How can I check to see if replacement is even necessary for these arms? https://www.fcpeuro.com/products/bmw...iece-lemforder |
12-30-2020, 09:38 PM | #2 | |
Neo-Luddite
2614
Rep 1,401
Drives: '06 325i, 330i 6MT RWD Sport
You could replace the wishbone and guide rods as in the kit you linked with M3 upgrade arms from ECS for @ $100 more |
12-30-2020, 09:51 PM | #3 | |
Rep 252
Is there a way to check if the bushings are shot on the other arms? Excess tire movement or something of the sort? |
12-30-2020, 10:06 PM | #4 | |
Neo-Luddite
2614
Rep 1,401
Yes, do a visual inspection first and if they look anything like mine do not pass go and order new ones. Then grab them and shake them, if the bushings are shot you'll know. The main control arm and trailing arm bushings are pressed into the subframe and axle carrier, obvs you wouldn't mess with the main control arm unless you have a problem or are doing complete rebuild, the trailing arm is an easy bolt on upgrade tho on the same bushings if they're good. I solve everything by taking it apart, even if you're not replacing them for a refresh as big as you're doing I would unbolt them and wire wheel the mount points and clean w/ new threadlocker/replace the bolts so the're not completely seized when you really do want to change them. The toe link is an easy bolt on too since you're going to need an alignment no matter what if you replace the wishbone and guide rods. Last edited by 3PedalJake; 12-30-2020 at 10:23 PM.. |
12-31-2020, 08:39 AM | #5 | |
Rep 252
Thank you for that info |
3PedalJake2613.50 |
12-31-2020, 02:36 PM | #6 |
Rep 1,525
Jake, what year is your car? My nearly 20 year old Jeep has less rust than that.
3PedalJake2613.50 |
12-31-2020, 03:31 PM | #7 |
Rep 1,510
12-31-2020, 06:34 PM | #8 |
Neo-Luddite
2614
Rep 1,401
It's an '06 330i. That is the worst spot and looks even worse with a flash closeup,,, but yeah it's pretty bad. It was a northeast car, that's what stuff looks like after 15 yrs or so. This car looks like it's had it's fluids maintained, they were all clean when I drained them but after that nothing. This is the only way to deal with such things,,,,
01-01-2021, 09:42 AM | #9 |
eBay Special
3122
Rep 3,042
Drives: E90 330xi
I still can't believe you got that exhaust looking the way it does. I mean I can, but what a difference
Common sense is a flower that does not bloom in everyone's garden
3PedalJake2613.50 |
01-01-2021, 02:23 PM | #10 |
Neo-Luddite
2614
Rep 1,401
01-01-2021, 04:00 PM | #11 |
eBay Special
3122
Rep 3,042
Drives: E90 330xi
Looks pretty close to new!
3PedalJake2613.50 |
01-02-2021, 06:45 AM | #12 |
Rep 76
Nice work!! Mine is a 2011 with only 50k miles, but it's always felt sort of loose and bangs over pot holes. Does your feel any different with the all the bushings your replaced?
3PedalJake2613.50 |
01-03-2021, 06:18 AM | #13 |
CHRISZACH1
146
Rep 140
Drives: 06 E90, 18 F80, 21 G05
I just installed this package on my 06 325i...man what a difference.
https://www.fcpeuro.com/products/bmw...e93-bmwmcaktfr
Sakhir Orange II Metallic / Black Extended Merino Leather / M-DCT / Executive Package / Competition Package / Driver Assistant Package/ 20" Frozen Silver Edelweiss LT 5 wheels/ KW V3's/ Mosselman Stage 2 tune
3PedalJake2613.50 |
01-03-2021, 01:44 PM | #14 |
Rep 5,025
3PedalJake2613.50 |
01-03-2021, 03:22 PM | #15 | |
Neo-Luddite
2614
Rep 1,401
Thanks, that's the aesthetic I'm shooting for: "zillion mile basket case that looks better than brand new". |
01-03-2021, 03:24 PM | #16 |
Neo-Luddite
2614
Rep 1,401
In the process of replacing them, but I can't imagine it's not going to be orders of magnitude better than the worn out stuff that came off it.
01-03-2021, 04:24 PM | #17 |
Rep 5,025
I’m sure you have a thread and a mantra on this, but be sure to put something in the rear subframe bushings. Either m3 rears or Whiteline inserts are absolutely amazing with zero downsides.
3PedalJake2613.50 Buug95918237.00 |
02-04-2021, 11:22 AM | #18 |
Rep 76
Was there ever an outcome from all this work? I'd love to hear details about how it felt and what you learned.
02-04-2021, 09:04 PM | #19 | |
Neo-Luddite
2614
Rep 1,401
Front: M3 E90 sway bar, M3 control arm, M3 thrust arm, white line adjustable sway link, new F.A.G. bearing hubs, Bilstein B8s and Eibach prokit springs, powerstop brakes, SS brake lines. Rear: 3.64 diff from auto trans car, subframe from a 335d, new GKN axles, M3 wishbones, M3 guide rods, M3 E90 sway bar manzo adjustable toe link, ECS trailing arm, Bilstein B8 shocks, Eiback pro kit springs, new wheel bearings, powerstop brakes, SS brake lines. |
Buug95918237.00 |
02-05-2021, 12:12 AM | #20 | |
Robot
1698
Rep 2,196
Up front I recently installed B4 struts and M3 thrust arms (same arm as the non-M really just a different/better bushing). I probably should have gone with B8 struts and I'm still thinking about it but even the B4s feel very harsh over the lousy LA roads. How much worse are the B8? On the back I'm overdue for new shocks. The dust boots disappeared and I can feel the back end hopping and losing traction over bumps while accelerating. Since I want to get another alignment after replacing the shocks I will probably install M3 control arms up front at the same time. I replaced my original shocks on my 325i aroujd 240K miles. To say they were worn out is an understatement, however surprisingly all of the rear arms/links/bushings were fine so I didn't bother changing them. I had that car aligned and new tires installed and it rides and handles perfectly. |
3PedalJake2613.50 |
