BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Battery issue or alternator issue?
      01-01-2021, 03:36 AM   #1
sollomon
Drives: M4,M5,M8C,X5M50I, X5M
2020 BMW X5M50I  [0.00]
2020 Bmw m8 competi ...  [0.00]
2018 BMW M4  [0.00]
2018 BMW M5  [0.00]
I replaced the battery cause of this issue 3 times so far. Originally battery was bad i knew that. It said to replace the battery so i swapped the battery with my other car which is compatible. And programmed successful. But that battery went bad too and i ended up with 2 bad battery.
This is the problem im experiencing, when battery is plugged to the charger voltage goes upto like 18-19 randomly and voltage doesnt seem steady. It goes up snd down so bad.
Because of this issue so far cluster had to be replaced because cluster got fried also.
If alternator is bad can battery voltage can go up and down crazy?
      01-01-2021, 07:46 PM   #2
AHall
Drives: 1993 Nissan 240sx
Did you register the battery and reset the charging system?
      01-08-2021, 01:56 AM   #3
sollomon
2018 BMW M4  [0.00]
2018 BMW M5  [0.00]
yes
      02-24-2021, 03:00 PM   #4
dawidk1978
dawidk1978's Avatar
Poland
51
Drives: 2021 M8 F93 comp
2017 BMW 540 xi  [0.00]
2021 BMW M8  [0.00]
Have you a special LiFe charger?
Gretz
Dawid K
      02-24-2021, 03:02 PM   #5
dawidk1978
dawidk1978's Avatar
Poland
51
2021 BMW M8  [0.00]
Max voltage for charging this battery is 14,4 V. When you have used higher voltage you probably damage the battery
Gretz
Dawid K
      02-25-2021, 01:47 PM   #6
northtorque
northtorque's Avatar
Drives: F90 2019
As others have mentioned. Double check your charger is rated for the Lithium battery chemistry. A standard lead acid charger will kill these batteries. Just saying this in case it was overlooked! If not, then best bet is a diagnostic looking for the infinite possibilities of cause. These batteries are crazy expensive and would hate to see you have another one fail. Good luck.
m5post
