oil level fluctuation
01-03-2021, 09:02 AM | #1 |
Rep 43
Backgound 2009 E91 328xi with 158k miles. Oil level was dead center for 2k miles since last oil change then dropped 1/4 down. I am not worried about that...Drove it to go snowboarding New Years day and its all uphill for about 75 miles and 6000 ft in elevation. On the way home ( downhill ) it was registering one quart low. I am new to non dipstick cars and I am not sure if it was the severe uphill or downhill that altered the level or does the sensor compensate for that. Got back into town and went to check buy some oil. Checked the car on a level surface the next morning and it was back to dead center which was higher than it was 2k miles ago. Is this "normal" or may I have a blocked oil passage or faulty sensor? The car has been very well maintained by the previous owner.
Thanks, Ed |
01-03-2021, 09:09 AM | #2 |
Rep 775
A little fluctuation is normal in mine. I've read that the car compensates for the grade you're driving on but I don't think it's very good at it.
I would continue to monitor for a few more drive cycles to see what it does. Keep some oil in the trunk in case it falls to low-low. |
Buug95918238.50 |
01-03-2021, 12:57 PM | #5 |
Rep 329
I've always checked when the car is warm but not hot such as a short drive or after the car has been sitting in the garage cooling down after a long drive but is still warm.
01-03-2021, 01:23 PM | #7 |
Rep 1,081
Normally, my 328i is parked facing up, one time when it was facing down the driveway (my driveway is fairly steep), it registered one quart low when I started the car. Don't worry about it, and measure it when the road is kind of flat.
Also, your car holds 7 qts, even if your one qt low, you're OK. |
01-03-2021, 01:29 PM | #8 |
Rep 18,835
When you say "dead center" what do you mean? The e-dipstick bar graph represents the quantity of just the top (i.e. the 7th quart of oil) in the engine. So a full bar from Min. to Max. means there are 7 quarts in the engine. So does "dead center" mean a full bar from Min. to Max, or does it mean the forward edge of the bar is in the center between Min. and Max?
If the bar is halfway between Min. and Max, then the engine is a half-quart low, so extended periods of uphill or down hill could report an artificial low reading. It's best to take an oil level reading on a relative level surface, just like you would with a mechanical dipstick. Once the ECU establishes an oil level, it is then updated every 20 minutes of continuous engine operation. Take time to read how the e-dipstick works. https://www.e90post.com/forums/showthread.php?t=1533444 Last edited by Efthreeoh; 01-03-2021 at 01:36 PM.. |
01-03-2021, 01:42 PM | #9 |
Rep 18,835
The ECU needs initially at least 5 minutes once the engine oil has reached normal temperature and the car has been driven so the system sees acceleration forward and side to side. If you start the engine cold, then sit with it running until the engine reaches temperature, you'll only get the last oil level the computer recorded. You have to drive the car for the level to update.
jsunma653.50 |
01-04-2021, 09:05 AM | #11 | |
Rep 43
01-04-2021, 11:16 AM | #12 | |
Rep 18,835
Why the Mods don't make my Thread a "Sticky" I'll never know.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
Cosmos9916.50 cliffschum15.50 |
01-04-2021, 07:03 PM | #13 |
Rep 1,081
The whole system is crap, crap, and crappier, and I think it was done so that BMW could completely seal the crankcase for emission purposes. BMW could certainly have given us, besides the dynamic measurement, a static measurement, which I think would make us all feel a lot better.
AWDBooSTIn90148.50 stewbets448.50 |
01-04-2021, 07:21 PM | #14 |
Rep 9,209
Oil level displayed vary depending on how fast or slow the oil get to operating temperature. If these times fluctuate so will the oil level displayed.
01-04-2021, 07:34 PM | #15 | |
Rep 6,319
I don't know if anyone else? This has really bugged me. |
01-04-2021, 08:50 PM | #16 | |
Rep 18,835
01-04-2021, 09:59 PM | #17 |
Nomore
149
Rep 793
I did some coding to my car. Partly bc I have an Idrive, Combox, & RVC retrofit and that requires VO coding (Vehichle Order/Option Codes). As well as the usual custom coding you would do for all that stuff and misc changes.
One thing I noticed somewhat recently is that my oil level always shows the same full mark on the picture of the dipstick in the CIC screen. As well as checking it thru the OBC on the Gauge Cluster Screen. Usually, as far as i know, you only check the oil thru the gauge cluster when you have a non-idrive car. And when you have factory idrive, you only check the oil thru the idrive menus. What are some signs of a bad oil level sensor or possibly a bad coding setting causing the gauge to always show full? I change my oil often and I know before I switched to 5w-40 Rotella Syn, i would use Mobil 1 0W-40 oem style oil. OEM Mann Oil Filter. I would usually need a quart in-between a 6-7k mile oil change using the Mobil 1 and the oil level gauge would tell me this and would go down slowly, as expected. However I did a bunch of coding bc of enabling more Combox related features like BMW Apps which is tricky and takes a few tries of coding settings depending on your year of car. At the same time i switched to the Rotella 5w-40, so im not sure if it really is doing nwhat I'd hoped and stopped burning off so much and getting hot. Which it did bc it never goes over 220/230f now vs the 250/260f with Mobil 1 0W-40 euro. I just want to make sure its full. Thats why i agree they should of just added a oil dipstick. To at least the N54 engines, damn bmw! Big mistake imho... |
01-04-2021, 10:54 PM | #18 | |
Is it the shoes!?
3885
Rep 5,112
If you put the key in the ignition position but don't start the car, it will tell you if there's sufficient oil to safely start and run the engine. |
Buug95918238.50 |
01-05-2021, 09:04 AM | #19 |
Rep 1,081
Yes, I'm aware of the 'go and no-go' alert, but an actual static level would have been great. Maybe someone could invent a dipstick for BMW! Imagine that, a dipstick!!
If it wasn't for my E90's magic steering and handling, I'd buy a Toyota. Well, maybe not a Toyota, but maybe a Mazda. That said, I did have a 90's Mazda 6 which was called a Japanese car with Ford quality. So true, so true. |
01-05-2021, 09:40 AM | #20 | |
Rep 6,319
Does anyone else experience the same thing as me? |
01-05-2021, 09:52 AM | #21 |
Is it the shoes!?
3885
Rep 5,112
01-05-2021, 10:45 AM | #22 |
Rep 6,319
When the level is calculated dynamically, like highway cruising for 20mins, the level updates to the actual level, at the moment I'm about half full on the dipstick, but every time I idle measure it shows full, even doing it how it says in ISTA/TIS. Also on a level surface. My sensor is also a new sensor from early this year so I'm sure the sensor is fine.
