01-05-2021, 02:52 PM | #1 |
Rep 529
Configure M button
Greetings, Happy New year everyone!! I know there are multiple threads regarding configuring the M1/M2 buttons. However, I have a specific question. My apologies in advance if this issue has been addressed!!
When setting up the M button you have a choice for the transmission between D1, D2, D3 or S1, S2, S3. I know the difference between selecting S mode (manual) or D mode (auto) using the gear shifter. My question is, how does selecting D vs S mode in the M button settings would affect the transmission if the gear shifter is actually in the opposite driving mode?? I really appreciate in advance your thoughts and input!! Stay safe and healthy!! Last edited by POBA; 01-05-2021 at 07:57 PM.. |
01-05-2021, 04:28 PM | #2 |
Rep 541
It doesn't matter if you're originally in auto (D) or manual (S). After you press your M button, the settings programmed on your M button override your current settings. You can press that M button again to return to your previous settings.
POBA273.50 |
01-05-2021, 09:34 PM | #4 |
Rep 541
01-05-2021, 10:23 PM | #5 | |
Rep 4,109
01-05-2021, 11:46 PM | #6 | |
Rep 541
01-06-2021, 07:01 AM | #7 | |
Rep 529
limeypride4429.00 |
01-06-2021, 07:28 AM | #8 |
Rep 1,807
The answer to your question is the car will change to what is program for the M button. After you de-activate the button it will return to what is selected by the shift lever. The transmission setting will be indicated on the display regardless of the position the shift lever.
01-06-2021, 08:19 AM | #9 | |
Rep 4,109
POBA273.50 |
01-06-2021, 09:47 AM | #10 | |
Rep 529
01-06-2021, 10:22 AM | #11 | ||
Rep 4,109
07-20-2023, 07:05 PM | #12 |
Rep 3
M1 & M2
Just purchased a 2022 M5 COMP and trying to set up my M configurations on this one. Had a 2019 that I just sold. I tried setting M2 button To Beast Mode (every cat Sport plus). Noticed the car doesn't down shift on it's own from 8th gear when I punch it. Shifter goes right into manual mode..
Is it because I have the trans setting on S3 not D3?? Thx |
07-20-2023, 07:54 PM | #13 | |
Rep 3,706
Drives: 2022 M5C
EDIT — Thanks to pmsteinm. Setting to D3 will cause it it shift to the lowest gear when you punch it, not downshift by one gear.
Not a BMW guy...but certainly an M5 guy.
NCDD0.00 |
07-20-2023, 07:56 PM | #14 |
Rep 413
Drives: 23 M5C, 19 X5
It will not downshift in manual mode when you floor it. You must shift down. If you shift while flooring it will jump to the lowest gear. The only time it downshifts for you in manual is to prevent engine stall while either braking or coasting.
ResIpsaLoquitur4158.50 |
07-20-2023, 08:00 PM | #15 |
Rep 3,706
Drives: 2022 M5C
Thanks for clarifying. I was not clear there. You are absolutely right. I did not mean that D3 will downshift to the next sequentially lower gear, but rather to the lowest gear possible. I suppose that a sequential drop by one gear is the stricter definition of “downshift” as opposed to shifting to a lower gear. I did mean it in the broader sense of shifting down, but not necessarily one gear down.
07-20-2023, 08:18 PM | #16 | |
Rep 413
07-20-2023, 09:02 PM | #17 | |
Rep 3,706
Drives: 2022 M5C
Sorry, tone is hard to convey on the internet! I didn’t mean to come off as aggressive — I was genuinely thankful for (what I thought was) a meritorious clarification. You are correct nonetheless. Thanks for being kind and civil.
pmsteinm335.00 |
