01-06-2021, 11:48 AM | #1 |
Rep 155
Swap pad depth between street and track?
I have a CP9449 in the rear with which I'm using D50 APF404 pads for street (yes they fit) and planning to get some D42 pagid pads for track. The pad spec I want for track aren't available in other pad depths by both ferodo and pagid.
The D42 pads might leave a small step on the rotor. Is it alright to swap between such a track and street setup? 15 or so track days a year. |
01-06-2021, 12:05 PM | #2 |
Rep 2,700
I am going to warn you right away with what happened to me last season.
On my front 9660 kit I ran ferodo ds11.1 for track and Porterfield R4S for street. My vendor told me it did not matter if the R4S were a little bit smaller. I did a track day on a small track with the street pads and fresh rotors but still pushed qui a bit, the day after you could clearly see the rusted ridge on the outside and the squeal was insane. So I swapped to Hawk Blues and tried to get rid of the ridge/rust, I tried really hard two times and now everytime I but the damn smaller street pads that damn ridge squeals like crazy ! May be less on the rear but if you can use a pad that fully cover the disc do it, it will save you this kind of headache later !
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
blitzyo53.00 |
01-24-2021, 08:27 PM | #3 | |
BimmerPost Supporting Vendor
3893
Rep 54,602
Drives: F80 M3
blitzyo53.00 |
01-25-2021, 01:43 AM | #4 | ||
Rep 1,262
Drives: BMW 1M
Running a pad with a smaller disc sweep area on track (or any other time) than your road pad and you will have a nightmare once you put your street pads back in. Any vendor that says otherwise needs deleting from your contacts. |
blitzyo53.00 |
01-25-2021, 12:10 PM | #6 |
3893
Rep 54,602
Drives: F80 M3
