01-13-2021, 06:04 PM | #1 |
Rep 341
Glossy black kidney grill and glossy black window trim set
Can anyone please recommend a glossy black kidney grill and a glossy black window trim set for a 2021 X3 and the website linked to it. I'm looking to do a chrome delete. Thanks
01-13-2021, 06:49 PM | #2 |
Rep 10
I recommend grills from either Autotecknic or IND. Personally, I went with the latter.
I'm unsure about window trim. You may want to consider a wrap. |
IND-Distribution9608.50 |
01-13-2021, 08:47 PM | #4 |
Rep 341
01-13-2021, 09:11 PM | #5 |
Rep 457
Drives: '19 X3 M40i
I also bought some gloss black grills from Taiwan (optimal_motorparts... not necessarily the same eBay seller as FWDavid). Shipped quick, quality and fit were on-point.
2019 X3M40i DGM/black vernasca, 2T4, 2VF, ZPX, ZPP, ZDA, DWS06+, etc, etc. Since July'19.
2021 X540i MSport CBM/black merino, 337, ZMP, ZPP, ZPK, etc. Since Dec'20. 2006 330i SGM/black, ZSP, ZPP, 217, HuberOps, M Splits, K Lines, AS 3 on EC-7. Sep'08-July'19. |
01-14-2021, 12:53 AM | #6 |
Rep 341
01-14-2021, 02:31 AM | #7 |
Rep 2,046
Drives: X3 G01 30i xDrive
You have to be little brave, then it's quite easy. Search the forum for more info, there are a few threads about installation Youtube videos too.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
01-14-2021, 02:50 AM | #8 |
Rep 23
https://www.ebay.com/itm/Glossy-Glos...97fd%7Ciid%3A1
This is the You Tube video that helped a lot. It is a bit harder to get off than he shows. |
01-14-2021, 07:21 AM | #11 |
Rep 341
That was another question, do you guys think it is easier to install the grill in the summer or really doesn't matter?
It's usually 45 degrees here where I'm at currently. So don't know if the cold will make it harder to remove the grills. |
01-14-2021, 10:47 AM | #13 |
Rep 5,115
Just do it in your garage. And don't go OEM for these grilles. WAY too expensive. Check the ebay links as others have posted. Great quality and significantly less expensive
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
01-14-2021, 11:52 AM | #14 |
Rep 2,046
You can also wrap them or use plasti-dip. I did the latter, not the best job ever, but as a first time use I'm ok with it. Obviously you can see the difference when looking close enough.
01-14-2021, 12:01 PM | #15 |
Rep 746
I paid 125,- for the BMW OEM grill (at a BMW dealer). Why pay 90,- for a chinese copy on ebay?
01-14-2021, 02:25 PM | #16 | |
Rep 5,115
If the OP can get them at the same price you paid, you should provide the OP with the link. Otherwise, the eBay versions are just as good frankly - and still $35 US cheaper than OEM...maybe the OP is on a budget EDIT: OP, I found this US site - $100 and, surprisingly they're OEM grilles
01-14-2021, 03:54 PM | #17 | ||
Rep 341
01-14-2021, 04:32 PM | #18 | |||
Rep 5,115
https://www.bimmerworld.com/Body-Aer...ont-Right.html
01-14-2021, 05:24 PM | #19 | ||||
A family of bimmers
2757
Rep 7,743
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
01-14-2021, 06:32 PM | #20 | |||||
Rep 5,115
So OP het the eBay ones likeoat do - I did on my previous X3. They look great and while they might be knock offs, I couldn't tell.
01-17-2021, 01:44 AM | #21 |
Rep 1,646
Anyone know why the black grilles have the 'filled-in' sides, while my original cerium-grey ones don't?
The black ones in the photo are obviously non-genuine, but from what I've seen even the genuine black ones have the solid sides... Is there a reason?
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
