What are jack point made of?
04-20-2006, 09:12 AM | #1 |
Rep 1,166
the square jacking point is made of soft plastic? they warp easily at metal contact points...
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
04-20-2006, 09:28 AM | #2 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
You need a jack that fits inside that plastic hole. Those side walls are not designed to take the weight of the car, as you have obviously found out. The cheap scissor jack I bought last week to fit my spacers had the appropriate adapter, but whether this is a Euro-only standard or not, I don't know.
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
04-20-2006, 09:42 AM | #3 |
Rep 1,166
thanks mate. cant seem to find any over here..
04-20-2006, 09:47 AM | #4 |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
when we were installing our PMBs last weekend, bavarian19 used a regular jack lift and it worked out alright. I expressed concern over the need for a specific adapter or at least in fashioning out blocks made out of wood (to fit the square and distribute weight evenly) but he assured me is fine...and it did. But to be on the safe side, I am looking for those adapter blocks for future project.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
04-20-2006, 09:53 AM | #5 |
Rep 106
Drives: E36 318ti, E90 325i
Yeah, the plastic jack points IMO are quite dumb.
Luckily, the jack out of my Lexus fits into the hole perfectly. |
04-20-2006, 10:04 AM | #7 | |
Rep 17,767
04-20-2006, 10:37 AM | #8 |
Rep 1,166
no offence SHIM, one question: you like orange most?
04-20-2006, 10:44 AM | #10 |
Rep 49
When changing summer/winter tyres, I just put a small wooden block on the metal contact point of my jack: the block burst but my plastic jacking points (at least three of them, since I wrecked the first one before I noticed it was plastic...) remained intact.
04-20-2006, 01:01 PM | #11 | |
Rep 805
Also did you just use a piece of pressurerised wood?
04-20-2006, 03:21 PM | #12 | |
Rep 49
I just took the first piece of wood that I found in my father's garage. No idea what the dimensions are but it is a little bit bigger than the plastic piece on the car. The wood itself is relatively soft, since the plactic things were pressed into it when I lifted the car. But the plastic itself remained fine... |
04-21-2006, 07:21 AM | #13 |
Rep 1,166
i think that wooden blocks are fine, my question is when car is lifted and the contact point btw the 'wooden insert-block" the the jack point form a flat surface which allow the flat saddle of your jack to lift with no problem or no damage to the plastic jack point.
but i really think this is not safe appraoch as the saddle of the jack has nothing to grip compared to the small saddle of another jack (used by some member) slotted right into the plastic jack point where the saddle and jacking point does not move about when the car is lifted. am i right?
04-21-2006, 09:10 AM | #14 |
Captain Caveman
150
Rep 1,715
A jack with a flat end would make me uneasy on ANY jack point. The only aftermarket jack I owned had little teeth which would mush their way into the soft peice of the wood.
Also, the purpose of the wood is not to go into the jack point, but under it. Although, going into it couldn't really be bad. Should be like this: Jack point....-->.........\_-_-_/ wood block..-->........===== Jack ...........-->..........n--n--n
E90 325i Monaco Blue, Black Leatherette, Sport, Cold Weather, Xenon, Sat Prep, 18" BBS RGR Mods: Polorized Film for Business CD, added lumbar, rock chip on hood |
04-21-2006, 09:16 AM | #15 |
Rep 10,185
The E36 had flat round hard rubber jack points
I wonder if you can replace the E90 one with a E36 one
BMW if you are reading, I need a job, Please. |
04-21-2006, 09:33 AM | #16 |
Captain Caveman
150
Rep 1,715
Didn't they also have jacking poles that you inserted into the side of the car?
04-21-2006, 11:07 AM | #17 | |
Rep 10,185
04-22-2006, 07:53 AM | #18 |
Rep 78
A small piece of wood plank will do the job. Does not even need to fit into the plastic hole. As long as the weight is distributed on the plastic evenly, it will take the weight.
04-22-2006, 10:18 AM | #20 |
Rep 1,166
hey, that's my 2nd prince...(Terrian). 2 kids at the moment...
your 2nd son as well?
04-22-2006, 10:45 AM | #21 |
Bimmer Manual all the way
68
Rep 1,811
hi bimmer 325i ,2nd son well had some jaundice but resolved.i have 4 kids, 2 boys and 2 girls. u must have ethnic chinese ancestry. your kid looks almost like pure chinese.
