01-25-2021, 01:54 PM | #1 |
Rep 685
I have called couple of KW dealers to identify a set of stiffer linear springs that I can go to instead of the progressive slightly softer springs that come with the M performance suspension. Does anyone have the serial number or the identification number for that spring set? The one dealer that I called in Maryland wanted to this information so that they can figure out the stiffer spring set that I could use with the existing dampers.
Thanks! |
01-25-2021, 02:48 PM | #2 | |
Rep 3,549
KW rear springs generally say what the rate and length is on them. Typically they have a number printed like "120-200" which is 120N/mm, 200mm length. The front spring PNs aren't descriptive and just a PN. For the specs you have to email KW for them.
For the M-Perf suspension the usual KW markings aren't there since they have BMW markings. If your front/rear perches take 60 or 65mm springs (measure the ID of the spring in there now), you have LOTs of options to retrofit. Here's an example where I changed the springs on a friend's B14 kit. Additionally on my own F31 suspension I'm doing something similar (using KW V3 F83 front spring on B14 based strut, and hyperco standard coilover spring in the rear). Quote:
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
GasBurnlife(landapanda)576.00 prompt292.00 |
01-26-2021, 05:52 PM | #3 |
Rep 433
Like FaRKle! said, the M Performance coilover springs do not bear the typical KW markings
Also, the springs are linear (not progressive) This is stated in the TUV Certificate and also confirmed by jetbill https://f87.bimmerpost.com/forums/sh....php?t=1590553 The front springs are/were marked 31 33 2 412 973 The rear springs are/were marked 33 53 2 412 975 However, it should be noted that realoem.com lists different part numbers for replacement springs The front springs are listed as 31 30 2 448 588 The rear springs are listed as 31 30 2 488 590 |
GasBurnlife(landapanda)576.00 |
02-09-2021, 12:23 AM | #4 |
Rep 485
This is a great post and a problem I am currently trying to figure out.
I have kwv3. My understanding is that the springs that come with them are only a tad stiffer than stock. On the track my car leans a lot. I am going to install a front sway bar and end links and I am hoping to figure out what 60mm swift springs I can go with. In the rear it's a straight forward 60mm spring 8" tall. My problem is the front. Idk what length I need in the front. 8"? But maybe that's too long. Maybe a 6" with a 2" helper spring? I'm trying to convert them to a linear spring and ditch the "comfortable" progressive springs. In hindsight I wish I never bought the v3s. But the price was right. I'm just hoping I can convert the front to a linear swift spring and have a decent set up for now untill I by MCS. Any help is appreciated |
02-09-2021, 11:07 AM | #5 | |
Rep 3,549
One thing you need to be careful of is making sure the spring you're retrofitting has enough stroke for the load capacity. This typically isn't an issue for these cars when the springs are >350lbs/in. I'd go to 2.5" or 65mm springs since they have a bit more stroke than 60mm. That and the dust boots (like the ones Bilstein has on their C/O) fit better in them (still a bit scrunched). For the range of springs the KW V3 are valved for, I can't see you running a high enough rate where a 6" long spring would make sense. You'll want to stick with 8". You could step up to the KW V3 F83 front spring. It's 265lbs/in, 9" long, and maintains the OE top mount ID, 60mm bottom perch ID. PN is 60210190, and they're $80 each.
02-09-2021, 03:08 PM | #6 |
Rep 1,962
Unless you've changed the top mount, on the front you're going with whatever is available for the M2/M3/M4 (or 2-series).
02-09-2021, 04:01 PM | #7 | |
Rep 3,549
He may also want to check how wide his bump stops are though and if they'll fit in a 60mm ID spring.
03-26-2023, 03:11 PM | #8 | |
Rep 269
Hi FaRKle! thank you for all these informations and your videos, really appreciate it. I would like a more flat ride style with my ohlins 1M set (60N/mm front ; 110N/mm rear) , sadly the conic spring is not Ø60mm but Ø65mm at the bottom. Do you know a company that sell a spring same as 60210190 ( aroud 45 or 50N/mm rate) but with a 65mm ID at the bottom? I would like to keep the conical shape for the maximum stroke. Thanks |
03-27-2023, 12:12 PM | #9 | |
Rep 3,549
03-27-2023, 12:44 PM | #10 | |
Rep 269
I think that i will lot have some issue with a KW 2025 and a 60mm ID at the bottom, by te way if i can find the same but with an65MM ID it would be better for the dust below clearance. |
03-27-2023, 09:46 PM | #11 | |
Rep 3,549
ornicar136.00 |
03-28-2023, 04:42 AM | #12 | |
Rep 269
04-04-2023, 08:28 PM | #13 | |
BimmerPost Supporting Vendor
3893
Rep 54,602
Drives: F80 M3
The alternative is to use an adaptor between the top mount and spring. |
