02-11-2021, 11:28 PM | #1 | ||
Rep 3,548
BMW M2/M3/M4 Suspension Deep Dive!
I thought it'd be fun to take a deep dive into the suspension on the M2/M3/M4. In the videos below I show you the design, layout, and some measurements of the F8x architecture. Additionally, Fat Cat Motorsports was kind enough to lend their expertise on our suspensions and measured the springs, bump stops, sway bars, and dampers (part 2).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 02-12-2021 at 12:53 AM.. |
11
CSBM52756.00 2020M2Competition430.50 ebisu81081.00 flybigjet6913.00 EtotheD305.00 Daytona_550468.00 BMW DIY Guy3109.50 bentom2335.50 mcvaughan706.00 Capt Canuck704.00 s0larian14.00 |
02-12-2021, 09:50 AM | #4 |
Rep 1,262
Drives: BMW 1M
02-12-2021, 11:14 AM | #5 |
Rep 89
thanks! I was surprised that the space between shock and bump stop is so small
even if people cut the bump stop or use shorter ones, I am pretty sure that heavily lowered car often do have no space between shock and bump stop at all! ride quality must suffer from that.. |
02-12-2021, 01:15 PM | #6 | |
Rep 3,548
It also applies to coilover kits too. If you take a B16 set and run it near the lower ride height vs higher you can feel the ride quality change due to the bump stop engagement.
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
02-16-2021, 09:51 AM | #7 | |
Life is on the Track, the rest is just waiting.
383
Rep 731
At a Point above 7,000 RPM.
02-16-2021, 10:14 AM | #8 | |
Rep 3,548
You know the fender to center of hub measurement from my video. Then add the radius of an 18" wheel to that.
02-16-2021, 10:21 AM | #9 |
383
Rep 731
Unfortunately I did not take a measurement before I started my suspension job. I have no reference point now. I'm trying to lower 10mm from OEM with my Ohlins. Would you know what the OEM measurement is?
02-16-2021, 02:05 PM | #10 |
Rep 1,962
Maybe just go with the MPS settings? So 595mm front/600mm rear (19") or 574mm front/579mm rear (18")
Both measured from bottom of wheel to top fender lip. HTH |
02-17-2021, 09:58 AM | #11 |
383
Rep 731
Delete
02-17-2021, 10:55 AM | #12 |
383
Rep 731
I would do that but my suspension recommends 10mm drop from OEM. I am not looking for more than that. Ohlins kit I have does not lower as much as others for optimum performance, which is what I am after, not aesthetics.
02-17-2021, 06:27 PM | #13 |
Rep 1,962
Well - to be clear - if aesthetics were the main reason for replacing the stock suspension I could have spent a lot less than the cost of the MPS.
it offers a 20mm drop over standard, so a little arithmetic should see you on your way. But. The Ohlins - surely - offers independent adjustment of ride height and spring preload for a given spring rate? So, perhaps you could explain how the damper is only good for up to 10mm of ride height change. It seems to defeat the object. Hope you eventually find what ever it is you're looking for. |
02-19-2021, 10:20 AM | #14 |
Rep 3,046
Drives: 2019 M2 Competition
Absolutely stellar information thank you!
In regards to sway bars: What I heard was rears are not worth changing, as the load is so minimal. For the fronts, I was incredibly pleased (as I am in the middle of a crank hub change) to see the front is SO incredibly easy to change. Is it worth it to change the front? I know that is a subjective question as the answer depends on usage model, which for me is 99% daily driver, 1% rare driving day, maybe track (some day) club driving event type of model. I am just stunned on how easy (by comparison to the front and rears I did on my F32) it would be to change the front.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
02-19-2021, 06:41 PM | #15 |
Rep 1,337
FaRKle! regarding the rear motion ratio of 0.76. In the video it is stated as 0.76 to the damper. What was the ratio to the spring?
Btw thanks for the videos! I think for part 3 you should go further in-depth how the rear motion ratio will be affecting your suspension choice since you have provided some info around the dyno graphs and wheel frequencies. Hint hint.
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
02-20-2021, 06:52 PM | #16 | |
Rep 3,548
Thanks for the suggestion for part 3! I'm sure I'll tie that into how I choose my spring rates for my bespoke FCM suspension (or maybe even an intermediate one...).
MR RIZK757.50 BMW DIY Guy3109.50 |
02-22-2021, 10:18 AM | #18 | |
Rep 3,046
With all of your analysis, is it worth it in general? Thanks as always for your analysis!
02-27-2021, 07:49 AM | #20 |
Rep 1,094
This is incredible, I learned so much!
For part 3 I would be curious to see an analysis of what stiffer springs (while keeping the stock dampers) do, mainly going from progressive to linear. |
02-28-2021, 02:10 PM | #21 | |
Rep 1,962
FaRKle!4040.50 |
02-28-2021, 02:16 PM | #22 |
Rep 1,962
Noting that there is always variability between dyno's (which is why you should always do Before:After on the same setup), JetBill's findings for comparison:
https://f87.bimmerpost.com/forums/sh...31&postcount=1 |
