02-14-2021, 03:19 PM | #1 |
Rep 47
Gloves for working on cars?
What is a good type of glove to wear - say for filthy brake work, oil changes etc - which will allow you to feel through the fingertips - but not snag and tear every five minutes?
And not make the hands all sweaty like latex do. Is there such a thing? |
02-14-2021, 03:21 PM | #2 |
Rep 1,336
I've never understood the need or desire to wear gloves when doing work on a car etc. I guess I'm old school and prefer the dexterity of bare hands followed by soap and water. Having said that I don't know about the use of latex or nitrile gloves, if I was going down that road I'd probably go for the more meaty type of shop gloves.
02-14-2021, 03:28 PM | #3 |
Rep 47
when you need reassurance from a youtube video - such as that good Ulsterman telling you how to delete swirl flaps - and you don't want to cover your computer in crap - that's glove time...
02-14-2021, 03:52 PM | #4 |
Rep 5,583
I like gloves. Even wear respirator when messing with brakes and dust.
Nitrite gloves are stronger than latex. And they are disposable for when doing fluid work. For suspension or in tight engine work https://www.mechanix.com/us-en/men/automotive |
02-14-2021, 03:57 PM | #5 |
Rep 1,336
02-14-2021, 05:34 PM | #6 | |
2006 TIME Person Of The Year
9709
Rep 6,445
Murf99314096.50 |
02-14-2021, 05:38 PM | #7 |
9709
Rep 6,445
Buy heavyweight latex gloves for most projects, with some Mechanix style for heavier tasks like changing tires. I keep both a box of latex gloves and Mechanix style gloves in my trunk at all times. Common uses for each is latex for cleaning my wheels; and Mechanix-style for topping off tire pressure or inspecting the treads.
02-14-2021, 06:47 PM | #8 |
Cole
328
Rep 498
I wear heavy duty latex gloves under my mechanix gloves everytime I work on the car. Latex keeps my hands clean from fluids and the mechanix protect them from sharp edges as well as heat. They also prevent the latex from tearing.
02-15-2021, 06:35 PM | #9 | |
Rep 388
Drives: GMC Denali
Same here. I also have mechanic coveralls in the shop for dirty work. |
02-15-2021, 09:34 PM | #10 |
Rep 2,539
Drives: 9Y0 Cayenne S
I tried the rubber/nitrile/latex glove thing and don't like it.
I have used suede-type gloves and it's not worth the hassle. Gloves get in the way. I prefer the feel on my fingers and hands. When I need to get into the car to turn the ignition on or turn the steering wheel, I either wipe my hands with a shop rag or go in the house and wash up. Gloves are a pain in the backside in multiple ways. |
02-15-2021, 09:56 PM | #11 |
Rep 658
7 mil nitrile gloves from harbor freight. box of 50 for less than $20 after the coupon. theyre not too thin to rip all the time and not too thick to prevent working on the car. They're just about right and if you do tear one then you'd put on a new one.
2005 Phoenix Yellow E46 M3 6MT Coupe
2007 Imola Red Z4 M Coupe 2013 Interlagos Blue E92 M3 6MT ZCP CF roof |
fiveohwblow3633.00 spazzyfry1235318.50 |
02-15-2021, 11:18 PM | #12 |
Roll Tide
609
Rep 2,364
Thick nitrile gloves for messing with basic and fluids, padded mechanix for doing heavy-duty work i.e. suspension parts or whenever in a situation that calls for applying a lot of pressure ot a bolt/nut that will result in banging knuckles on something when it releases.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
02-16-2021, 07:56 AM | #13 | |
9709
Rep 6,445
02-16-2021, 08:02 AM | #14 |
Rep 1,293
So I typically keep a couple boxes of Harbor Freight 7mil gloves in the garage for general maintenance. When preparing to do my rod bearings, I grab a couple additional boxes of gloves from Pep Boys. The brand was called Diamond Grip. Initially I thought the Diamond Grip gloves felt thin. What was interesting was how tough they were compared to the Harbor Freight gloves. In addition, when covered with oil, the Harbor Freight gloves were super slippery whereas the Diamond Grip gloves actually had improved grip. If working on something where feel and grip are paramount, I would recommend Diamond Grip gloves, but for general maintenance Harbor Freight gloves work fine.
unluky7698.00 |
02-16-2021, 09:06 AM | #15 |
S.FL S65 Specialist
4094
Rep 4,116
I usually have 3 types of gloves around.
When I used to work in a shop full time, I almost rarely wore gloves and just washed my hands all the time. Now I no longer work full time as a tech, I tend to take my time when working on cars, keep my work environment and tools cleaner and more organized and prefer using gloves now. I don't have a brand preference, I buy whatever is cheap or on-sale HF/amazon/costco/etc. I just group them into different thickness. Everyone has their preference.
ToddinTN504.00 |
02-16-2021, 03:38 PM | #16 | |
Rep 1,819
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
