02-16-2021, 06:08 AM | #1 |
Rep 73
Drives: 2020 BMW X4-30i (G02) M-Kit
Shadow line trim fading
Seems like my shadow line trim on the door is fading. Nowhere else on the car. It's a bit hard to see. But has it happened to anyone else. I can see the metal underneath!
02-17-2021, 01:22 AM | #2 |
Rep 913
With strong sun and thin paint it is possible you have a problem and are able to see it in good light. Many forum members have reported thin paint on BMW trim parts including front fender/bumper, at least one other forum members has had faded trim replaced under warranty. I would suggest you get a competent car paint specialist to check the paint thickness (using paint thickness gauge) and colour match for the whole car. It may require a repair (re-spray) /part replacement under warranty. With modern manufacturing some trim parts arrive at the factory pre-painted by the supplier, the paint thickness on the car will vary but if you can actually see a problem then it must be bad.
02-17-2021, 05:40 AM | #3 |
Rep 4,107
Had that happen on my M3 and the dealer replaced under warranty.
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
02-17-2021, 07:56 AM | #4 |
Rep 26
Drives: BMW X3M
I had the same issue on my 2016 M3 after 2 months of ownership. Replace under warranty.
With the M40i, I have my detailed shop covered with Optic Coat Pro now is sealed for 5 years🙂 |
