03-02-2021, 03:33 PM | #1 |
Rep 104
OEM Swaybar Sizes
My 30e's suspension is a little soft so I was wondering what size sway bars the different models have. I looked them up on realoem and summarized here:
Edit: earlier 30iXs show a rear bar. Everyone should use realoem to dig deeper for their own situations. Thoughts:
Might be some nice OEM+ upgrades here for lower level X3s. The sway bars are like $220-250 each. Last edited by TXBDan; 03-28-2021 at 12:49 PM.. |
03-02-2021, 06:23 PM | #2 |
Rep 457
Drives: '19 X3 M40i
Good find... subscribed for armchair and practical convos about suspension and spring rates. (M40i is too stiff for less-than-perfect roads, I have some theories but no means to try them out)
2019 X3M40i DGM/black vernasca, 2T4, 2VF, ZPX, ZPP, ZDA, DWS06+, etc, etc. Since July'19.
2021 X540i MSport CBM/black merino, 337, ZMP, ZPP, ZPK, etc. Since Dec'20. 2006 330i SGM/black, ZSP, ZPP, 217, HuberOps, M Splits, K Lines, AS 3 on EC-7. Sep'08-July'19. |
03-02-2021, 09:29 PM | #3 |
Rep 911
Drives: 2020 X3 M40i
Do you have the adjustable dampers? I am pleased with the M40i with adjustable dampers. 21" RunFlats don't help.. but still not bad. I will replace with non run-flats when these wear out.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
03-02-2021, 09:42 PM | #4 |
Jumping Jack Flash
324
Rep 1,692
Drives: 2021 X3 M40i
I don't find the 2021 X3 M40i all that stiff, but I am coming from a highly modified suspension on a 335d. Plus I purposely ordered 19" wheels with aspect ratio 50 tires. But so far I have found the cushiness quite to the liking of my wife who did not like riding in the 335d, and it had only aspect ratio 40 tires in the Michelin Comp 4s. But when I want to tighten the X3 down, it just goes in Sport or Adaptive mode and I am good for the twisties.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
03-03-2021, 10:57 AM | #5 | |
Rep 457
Drives: '19 X3 M40i
First order of attack will be non-rft, but I'm on the fence whether to go square and taller sidewalls, or hope that a mellower tire (Conti DWS06+) in oe sizes will chill things out a bit. Curious what the wheel spring rates are (famously difficult/impossible to find... not listed at RealOEM even)
2021 X540i MSport CBM/black merino, 337, ZMP, ZPP, ZPK, etc. Since Dec'20. 2006 330i SGM/black, ZSP, ZPP, 217, HuberOps, M Splits, K Lines, AS 3 on EC-7. Sep'08-July'19. Last edited by prototyp; 03-03-2021 at 12:23 PM.. |
