03-14-2021, 04:32 PM | #2 |
Rep 324
I'm not sure if it's the same on the 550, but check your clearance over the rear cross support (just in front of the rear diff). I had some rattle issues after fitting my downpipe and had to lift it slightly.
The other thing that can rattle is the MPE exhaust tips. Not sure if you have those, but if you do, give them a slight rap with a rubber mallet to check if they are causing it. They have an outer shell that can rattle against the interior casing.
G30 540i M Sport | MPPSK | VSRF Catted d/p | Burger Intake | BM3 Stage 2 | XHP Stage 3 | FTP G-58 / G3X
03-17-2021, 04:30 PM | #4 |
Rep 324
So only during startup.. not driving?
Have you done any mods? Just drop into an exhaust shop or dealer and get them to put it on a hoist. Once you can get comfortably under the car, those kinds of issues are usually identified and sorted out fairly quickly.
03-29-2021, 04:35 AM | #7 |
Rep 298
I do have a minor rattle which sounds a bit similar in mine. Most noticeable on a cold start and at low revs like you noted. As I've only ever really noticed it when I'm in the car I've not been able to find where it's coming from. It sounds like it's near the rear of the exhaust
03-29-2021, 07:42 AM | #8 |
Rep 493
Car currently at the dealer to figure it out. They could t hear it when I arrived as the car was all warm. Tech says it might be normal during cold start as the flaps on the turbo are not meant to be tight.
