03-30-2021, 09:49 PM | #1 |
Rep 47
Re-indexing after spring install
I don't see many posts about this, but just wanted to see what people do when putting on new nuts and bolts to re-index the bushings. I'm having a hell of a time figuring out how some of the bolts can be pulled out with the subframe still on the car (specifically the rear ones). Also what's the trick to tighten the bolts when the suspension is under load, there is a lack of space to get a torque wrench in there when trying to do it from the bottom, my next attempt will be to drop the car down with blocks under the lower control arm to compress it with the wheel off and tighten it that way hopefully. Additionally, are people only doing bushings that are vertical, or horizontal ones too?
Lastly, I ran into a situation where the control arm that attaches to the hub came out and I noticed little dimples sticking out of it and small indents on the hub that they fit in, I tried to align them but in a scenario where they are not pressed together, is there risk of failure? Thanks! |
03-30-2021, 11:41 PM | #2 | |
Rep 3,549
Yes, it's an absolute pain to work on the rear control arms, but it is doable without lowering the subframe. I replaced almost all the arms on my F31. You do need to torque them at ride height, and you can use a jack to lift the wheel carrier up to the normal position.
You may have to get creative with torquing them such as using crows feet wrenches or offset torque tool. I was able to do all of my F31's with crows feet. As for the little dimples on the ball joint face, don't worry about indexing those, it's not needed. You can see my F31 rear arms swap in the below video: Quote:
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
MikeD943.00 |
03-31-2021, 10:06 AM | #4 |
Rep 438
I have heard by very very reputable mechanics that none of this needs to be done . So many people just swap coilovers in and have zero issues .
03-31-2021, 02:32 PM | #5 |
Rep 1,962
BMW don't suggest it with the MPS - but then the lowering isn't huge.
Although the instructions say torque them up at ride height (which can be achieved in a number of ways), if you do them up enough to seat them at ride height - so they won't move if you jack the car up - you can then torque them fully with the wheels in the air. |
