04-02-2021, 02:18 PM | #1 |
BimmerPost Supporting Vendor
9599
Rep 10,891
IND G8X M3 / M4 Painted Front Reflector Install Guide
Painted reflectors are always among the first additions made by any owner of a modern BMW. Thanks to the U.S. DOT, the unsightly orange reflectors installed in cars bound for North America continue to break the smooth lines of BMW bumpers. While it appears BMW is trying to mitigate how much reflectors stick out like a sore thumb by now slightly tinting them on the G8x chassis, IND continues to provide painted reflectors as a cost effective solution relative to the purchase of a OEM European bumper. We start the process using the OE BMW reflectors for a factory fit, and the same paint process we would use to spray an entire car. Each reflector is sanded, prepped for paint, primed, then painted. We ensure that all lettering on the face of the reflector is completely removed providing the same finish as your factory bumper. Many enthusiasts enjoy installing their own painted reflectors, so we’ve created this installation DIY to help. Tools needed:
Step 1: First, we recommend removing the wheel as it provides more space to work, but you may find it easier to simply turn the steering wheel to full lock so wheel is facing inwards. This will allow you to see the back of the reflector exposed within BMW's front air Step 2: Next, if you are new to installing reflectors and using a heat gun, apply a layer of painters tape around the reflector. This will give you some extra protection to prevent any burning of your paint. Take the heat gun or hair dryer and fan over the reflector being careful not to get too close to the paint. This will help soften the adhesive on the OEM reflector. Step 3: Press on the lower portion of the reflector with your thumbs while using your fingers to pull the bumper towards you. Once the reflector separates from the body, place your bondo spreader between the reflector and bumper. Continue to work your way up, alternating between pressing with your thumbs and moving the spreader up until the reflector is free. Step 4: After the reflector is removed from the bumper cover take a cloth and some adhesive remover, or using your finger, remove any excess adhesive. Step 5: Now that the surface is clean, remove your painters tape and the adhesive cover on the painted reflector and push reflector in place. Make sure to apply even pressure around all edges. Step 6: With the reflector installed, reinstall the wheel if you removed it for installation.
mattssi880.50 jonahk705.00 JTO245276.00 emescopa31.50 yousefnjr6190.50 NightWriter4844.00 trad8.50 SkyNinja8326.00 |
05-14-2021, 05:21 PM | #2 |
9599
Rep 10,891
Video added.
05-16-2022, 10:40 AM | #4 | |
9599
Rep 10,891
We do not offer them in a clear reflector.
05-23-2022, 08:56 AM | #6 |
9599
Rep 10,891
Most individual colors can be requested by sending us an email at info@ind-distribution.com
chicagofan0019266.00 |
05-23-2022, 09:20 AM | #7 |
Rep 7,007
Drives: 2022 DG/BLk xDrive M4C Wk 34
The scariest part is putting a heat gun to the paint. I was checking the temp by touch, after every pass or two. Also, pay close attention to where you lay the painters tape, if your front end it PPFd. You don't want to get a piece of tape too close to the PPF edge, or you may pull off some PPF.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
NightWriter4844.00 |
05-23-2022, 04:49 PM | #8 |
Rep 401
I used a hairdryer to avoid scorching... I doubt it got it as hot as it would be sitting in say Arizona direct sunlight, where as the heat gun would like bubble the paint.
Limegrntaln13569.50 |
06-27-2022, 10:11 AM | #9 | |
Rep 7,007
But probably not any hotter than it would be sitting out, baking in the sun. Remember, touching the hood of a car, after it's been sitting in the 100° sun, gets hot enough to burn your hand, but doesn't bubble the paint.
YT: G Dubyou |
element561092.00 |
11-11-2022, 10:28 AM | #10 |
9599
Rep 10,891
chicagofan0019266.00 Limegrntaln13569.50 |
11-11-2022, 12:56 PM | #11 |
Rep 315
Drives: 2023 G80 M3 x-Drive Comp
Do you offer these for colors not listed on website? Looking for Frozen Pure grey metallic ii
11-11-2022, 02:14 PM | #12 |
Rep 8,084
Drives: 2024 X5 M60i
Yes, they can do other colors. Just shoot them an email or give them a call.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
11-11-2022, 08:58 PM | #13 | |
9599
Rep 10,891
Limegrntaln13569.50 chicagofan0019266.00 |
11-12-2022, 09:27 PM | #14 | ||
Rep 1,683
11-14-2022, 11:25 AM | #15 |
9599
Rep 10,891
No plans on making clear reflectors.
